Superlap 2010 Ramblings
That's a pretty big job card assuming you're not planning on any machinery. I hope your dirt/rock ratio is not like ours, hand digging up here is very hard work I use the Mitre 10 in Sloane St or Gehl's Nursery where I can rather than Bunnings, but for bulk material everything (Goulburn Sand and Soil, Rocky Hill Sand and Soil) and is owned by Divalls (as is about 80% of town) so no point shopping around. Let me know if you need to borrow a ute or box trailer. BTW we also went with 7mm blue metal around the house, mostly for fire but also termites. You really need compacted road base under it then no more than about 50mm of rocks because otherwise they shift too much under foot. We also put corten edging to stop it spreading outside its area over time.
I'm not certain about the fuel hat connectors (noting, I DID have to replace the hat in my Stagea with one of these pumps) However, you 100% do need to do a properly sized relay mod, the factory wiring is definitely too small for these pumps.
Those Efi bulkhead terminals have been in the car for about a year now, they are perfect. So, upgraded wiring, relay mod, uprated terminals and you can run that pump flat out all the time no issues.
