R33 Skyline Number 9 On Top 10 Greatest Ever Sports Cars
  • Replies 109
33 gtr drifting? awesome documentary :D
gtrs in my understanding are fkin king of tracks (bathurst anyone?)
infact..
32gtr should have won due to OWNING bathurst and getting kicked out lol
but 34gtr is i reckon the hottest sexiest beast of the skylines
R32 GTR should have been in that documentary, because as a sports car, its the best one out of all of them. Having said that, I chose the 33 out of reliability (not as old), looks, and price. Still, would take a 33 GTR over a 32 GTR.
In the end, its personal opinion. Everyone's is different
cant believe some of the cars in the top 10, miata @ 2??? 911 in first?? funny how they said the skyline is tunable from the factory, it isnt, but they had a power FC in there, so it becomes adjustable!! wat a bunch of idiots!! i would of said GT40 for first, because of racing pedigree!!
yeah r33 totally suck
i mean,
who would want 500cc more engine capacity
larger standard turbo
tougher gearbox
bigger brakes
battery in boot
Specs for R32GTST
Dimensions
Length 4580 mm
Width 1695 mm
Height 1340 mm
Wheelbase 2615 mm
Turning Circle 5.2 m
Chassis & Body
Curb Weight 1320 KG
Performance
0-100 6.5
0-400m 14.8
versus
Specs for R33GTST
Dimensions
Length 4640 mm
Width 1720 mm
Height 1340 mm
Wheelbase 2720 mm
Turning Circle 10.4 m
Chassis & Body
Curb Weight 1360 KG
0-100 6.18
0-400m 14.4
total peices of crap. burn them alive I say.
I just can't seem to figure out why there are more on the roads then the god-like 32. :)
Those facts are great.
The R33's turning circle is double the R32, and with its extra 500c and bigger turbo and more awesomez it only gets to 100 0.32 seconds faster, and down the quater mile 0.4 seconds ahead of the smaller, weaker, not as good, obsolete R32.
With all that aside, the list is a fail, not for the R33, just for the rest of the list.
Doesn't the RB20 run 10 psi boost vs 7 psi on the RB25?
The 33 GTST is basically the 'drift' version of the 33 GTR. :D
Turning circle is crucial for Taxis. :P
Steering lock is also good for DRIFT, but hey, with 4 doors, you get LOOOOTS of lock, awesome for getting the cutomer to the airport on-time.
Don't you smoke crack?
Dunno what R32's run, Cefiro's run lower boost from the factory, so I dunno, somebody with a decent Skyline can answer that question for you.
Lack of boost is combatted by extra displacement, newer technology, oh, and those great turbo's and injectors and ECU and all the other goodies R33s have which R32s don't.
This thread is ammusing. Waves of brainless sheep praising their cars because some b-grade footage said they're awesome. Not exactly anything new though.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
