yep fine just a bump on the head from the hans/helmet
check out the thread he has posted some in car footage... looks like a brake failure of some sort... and then some brain fade as he still tried to turn into the corner with waaay too much speed... hit the sand sideways and the rest is pretty evident
why does that track have a massive drop off before the sand trap?!?!?!?!
yeah check out the aston martin.....
for some reason my embed for viseos does not work, can someone email me the code? save me posting links (i reckon chrome is the culprit)
another mid ohio
http://www.youtube.com/watch?v=fRC3rv1ZHj4...feature=related
Edited by URAS
yeah it's a bit dump. the vid of the aston martin shows what happens when you hit it. you get airborne and miss most of the gravel trap.
here's the incar from the zed. you can see as the crash starts he hits the lip and gets airborne and is just going to fly over most of the gravel trap regardless of whether or not it cartwheeled.
and you can see this crash at the same spot starts almost the same way. car hits the lip, gets airborne and misses half to two thirds of the sand trap and ends up in the the wall. having the sandtrap fall away from the track edge like that just doesn't work. nor does the lip before you hit it.
the astons flight does look quite graceful though... lol.
lol, same time! d'oh.
that BMW crash is nasty. shame too as the driver did all the right things, he countersteered enough to keep the car straight, slowed down as was motoring along happily until he hit the stunt ramp which just completely fked his day.
How could the safety design elements of that track be ok'd by any governing body worth their salt is beyond me......
quite seriously though, how they'd have/still have public liability insurance with run-offs like that is beyond me
well..... they are americans...... ;)
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
