yep fine just a bump on the head from the hans/helmet
check out the thread he has posted some in car footage... looks like a brake failure of some sort... and then some brain fade as he still tried to turn into the corner with waaay too much speed... hit the sand sideways and the rest is pretty evident
why does that track have a massive drop off before the sand trap?!?!?!?!
yeah check out the aston martin.....
for some reason my embed for viseos does not work, can someone email me the code? save me posting links (i reckon chrome is the culprit)
another mid ohio
http://www.youtube.com/watch?v=fRC3rv1ZHj4...feature=related
Edited by URAS
yeah it's a bit dump. the vid of the aston martin shows what happens when you hit it. you get airborne and miss most of the gravel trap.
here's the incar from the zed. you can see as the crash starts he hits the lip and gets airborne and is just going to fly over most of the gravel trap regardless of whether or not it cartwheeled.
and you can see this crash at the same spot starts almost the same way. car hits the lip, gets airborne and misses half to two thirds of the sand trap and ends up in the the wall. having the sandtrap fall away from the track edge like that just doesn't work. nor does the lip before you hit it.
the astons flight does look quite graceful though... lol.
lol, same time! d'oh.
that BMW crash is nasty. shame too as the driver did all the right things, he countersteered enough to keep the car straight, slowed down as was motoring along happily until he hit the stunt ramp which just completely fked his day.
How could the safety design elements of that track be ok'd by any governing body worth their salt is beyond me......
quite seriously though, how they'd have/still have public liability insurance with run-offs like that is beyond me
well..... they are americans...... ;)
  • 1 month later...
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
