bit of a list:
S2 full interior (front+rear) good condition $300
radiator support panel $250 (tell me where you want it cut)
Ignition barrel + driver door barrel + key $100
S2 dash (with passenger airbag & panel) $250
Auto Gearbox with stage 2 shift kit $500 (unknown condition, apparently works fine)
GTR Boot lid wtih hinges (No Wing) $100
S2 Steering wheel with airbag $300
rear tail lights pair $200
centre garnish (white) $50
rear corner windows $50ea
stock suspention set $200
Seatbelts, full set $100
Instrument cluster $120
White R33 fuel cap $50
Standard Rb25 BOV $50
rear view mirror $50
Auto tail shaft $150
steering rack $180
back bumper $100
rear window $100
driver door with glass and motor $150
diff $80
Centre console (no handbrake boot cover) $50
hood lining $50
carpet $100
rear sway bar $50
driver mirror $50
Electric antenna $50
A/c control gc $120
drivers side Blinker on the guard, indicator switch on the steering column, surround on the window switch on the drivers side door
drivers side blinker as in the whole indicator?
r33 indicator stalk $50
surround i have has carbon fibre vinyl on it $40
Hey mate do you have the plastic bit that fits under the car stereo ? (Skyline R33) http://www.skylinesaustralia.com/forums/po...26-IMGP0142.JPG (example) put the keys and stuff in it... im in Melbourne if you have it might need to post it out or something.
Edited by DarkRyda
whats the boot trim like?
well its not in the car , but its all excellent condition , just gotta work out how many pieces go with it, also have the piece of wood that goes over the spare, im pretty sure its all complete
  • 5 months later...
should actually keep this up to date hey ...
steering wheels gone
parts left over :
auto gearbox
front glass
rear glass
1/4 glass
drivers side window
drivers side door with lock
ignition barrol with key
hicas unit with toe arms
hubs
knuckles
front uprights
boot with lock
abs unit
hey mate, how much for the front knuckles, are they in good knick? mine have a fair bit of play and not sure how regency will like that. I have no idea what they are worth.
they are still on the car at the moment but im pulling them off tonight
last i checked they arent cracked or anything
$100 for both with uprights
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
