Not quite gauges but gauge related, the A-pillar mounts. I just bought a single a-pillar mount to fit my 60mm boost gauge (HKS Direct Bright...mmm....) but as it's a generic gauge holder, it needs to be modded to fit on my A-pillar. Do you guys know who can do this?
Cheers.
greddy duel gauge pod
lower - boost (apexi el2)
higher - empty for now. get an oil one eventually
as for the pods bein expensive, ***in oath they are, BUT, the quality of an expensive one is right up there. mine has the factory look, wrinkles in the plastic just like the dash. i got one for my silvia (which didnt even fit gauge - never installed) and while it was nice it was cheap and nasty compared to my overpriced greddy item..
+ i said i was gonna do shit properly on my next car :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
