  • Replies 108
Why would they make you destroy something that you have paid for?
Just because it needs to be complied as stock, doesn't give them the right to destroy your legal property, I would imagine.
Sounds moore like dodgy compliance yards trying to keep an exhaust system for free to me.
My 2cents
Guest darrinspencer
My 2cents
Under the new rules cars or to go straight from the docks to compliance in a standard stock form
If they are fitted with aftermarket parts of any form they are to be removed destroyed and proof shown that has been done and stock parts refitted.
That's why you are better buying a stock car and not having that new HKS2835 pro S turbo get removed and destroyed. that would really suck.
I stand corrected.
Wow that isn't very fair.
Lucky JL Newton has found a decent complier.
Hmmm makes me think a bit more seriously about what I will buy when I import a GTR later on, next year.
Yeah, you cannot bring in anything modified anymore, but try and find a GTR in Japan that doesn't have a cat-back exhaust, almost impossible, especially considering age would be starting to catch up with factory exhaust systems. And who would replace it with a standard exhaust. Another part of the compliance is brakes have to be completely rebuilt using factory Nissan gear which comes in at around $2k, I could have used that money for slotted rotters and endless pads, and it would stop a hell of a lot better than standard Nissan stuff. Anyways, thats the rules!
Yeah, I just don't want to remove too much stuff, it seems hard enough to get interest in the GTST as it is, let alone with all the good stuff taken off. Luckily for the me the camber kits are are the same between the GTST and GTR, just need the adj. caster rod and sway bars, and I already have a nice set of fully adj, Apexi T-max coilovers sitting in my lounge room floor. Suspension is done!
congrats - sounds like a nice car - wats ur old r33 goin for?
Thanks mate, not really sure what $s to put on the GTST yet, there is such a wide range of prices out their??? It won't be up for sale until probably late Feb, I am thinking somewhere between $16k and $19k. If it goes as low as $16k I will be taking all the good bits off and selling them. There are a few guys here interested in some bits for their track exploits. (Cusco F & R strut braces, DBA slotted clubspec rotors, Cusco radius rod, bilstein shocks, O2 Rush pod and UAS Cold Air Box, etc)
cant you import it without brakes, and get it complied witht eh better brakes here?
Nah, has to be complied here with genuine new nissan bits for the brakes, amongst other things, they are very tough now. The new rules basically try and get the cars as close to new/showroom condition as possible considering age. Everything must be stock, and I mean everything. Can't be all bad I suppose.
Still, I am sure the original Brembo/Nissan combination can't be that bad!
its crappy about the stock as a rock thing.. but they know full-well the parts would just go back on, or onto the market if they did.
Nice car.. don't think i have seen a white 33 GTR up here yet, then again i have only been here about 3 weeks :P
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
