  • Replies 108
MMMMMMMM, so much fun, pics tomorrow. Having issues with my USBs at the moment. Didn't take Glenn long to spot me! Had only just driven back from the Gold Coast at that time. I have to say at the moment I am VERY happy, it is soooo clean.
Cheers, I fitted the BBS wheels last night, plus all the other little bits and peices. Also fitted the slotted rotors today, they look the business behind the wheels, thanks goes to "Dominic" for the rotors and the "vspecv" for the rims, they look great. SAU is full of bargains! I went to fit all the suspension bits today aswell but hit a snag. Went to pull the rear upper arm off the put the adj. cusco one on and it was so tight I broke the socket, so promptly gave up! Might have to get someone to fit it all.
I KNEW IT!!!
told you that you would be doing that after you got home from my place :P you JUST couldn't wait....
sigh... too bad about my dinner appt else i would taken up yr invitation too.
I find it amazing that your GTR went into the same complience place as mine (but 3 weeks later) and you are driving your already......my black GTS-t has been down there for almost 6 weeks now and i am less than impressed with the workshop.
I look forward to finally taking my baby away from those "people" and getting it on the road.
but hey, congrats on the GTR they sure are a bit of fun!
haro
Not sure I qualify as someone who "knows" how to drive a GTR yet, confidence is definately not there yet. Its a totally different car to drive than the GTST, it feels bigger, heavier, initial turn in is not as good, the seating position is a little different. It not heaps quicker than the GTST but feels torquier and can definately stretch its legs better on the highway! Even though it has a stock exhaust, the engine noise is completely different than the RB25. Basically totally different, can't wait to test it out properly at the track!
Sorry to hear that Haro, its sooo frustrating waiting for the car to turn up, took about 5 weeks for mine to go through. It all worth it though. Can't wait to get a look at that carbon wing blade!!
Still can't get any pics up, really hate computers sometimes, looks like I may have had a USB failure so my pics a trapped on my camera at the moment.
Still can't get any pics up, really hate computers sometimes, looks like I may have had a USB failure so my pics are trapped on my camera at the moment.
Finally I have some pics! This is how I picked the car up, have yet to wash it. I have just fitted the different rims and tyres, clear lenses, slotted rotors, seat covers, and a few nismo "rice" things.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
