Ok I am realy pissed at Wolf 3D for selling me this Ecu for my skyline it was a plug and play unit, but that was no where near the case.
Ok I but the unit and hand a work shop fitthe unit and tune it for me ...ok no problems! They fitted the unit ok plugged straight in and and they tuned the unit.
Ok in the tuning process the car was pinging and stuff ok the tunners rang up steve at Wolf and he said that 3 out of ten skylines have this problem. Ok fair enough so he sold us a new trigger switch for the car. Ok to fit this to the car the original unit had to be moderfied (OK NOT A PLUG AND PLAY UNIT NOW) any way this cost me some extra cash and it didn't sort the problem! .........#*@^ !
ok we called wolf again and he said to try wiring in some resisters in the loom .......we said what the #*@^ isn't it a plug and play unit, he then said that 'MIGHT' fix the problem. anyway we said his unit was a not what was stated, and returned it.
he also said it might be the car but the car was fine with the standard computer.
But I had to return the trigger switch back to standard. and the tunner spent 3 days on the car to get it to work + machine work fuel and track time. cost me a pretty penny in tune time and shit.
so to anyone thinking to get one of these WOLF units fitted into there car think again! nothing but problems!
:D:) :) shame ,shame, shame.
https://www.sau.com.au/forums/topic/29793-wolf-3ds-not-a-plug-and-play-system/
iv had no problems
plugged in, tuned and on my way...
its been two years now
I second that!
Unit is only as good as the tunner, and if the tunner does not know how to use the Wolf properly, then it's just asking for trouble.
Is there such a thing as a series V or 8 wolf? are they newer than the one Al and Whistla has?
I was mighty impressed by Al's unit, and was considering one.... hrm, maybe i should stick instead to tried and tested units instead.... Does anyone have an FCon V installed by any chance?
I've just bought a V4 Wolf3D plug-in for my R33 GTST, I know it's a V4 Rev5, don't know about V4.55 :confused: It has gone in my Skyline a couple of times and I still haven't got it working properly as yet but I haven't taken it to get tuned in properly yet, my Skyline is a Auto and as far as I know the Wolf's don't have a problem with the Auto's.
My Skyline is Standard other then a Jamex panel filter and the base Map didn't work with that, Steve-sst emailed me a Map and it worked, I just cant get it to idle as yet and I need to have my foot slightly on the accelerator to keep it at idle, when I let my foot of the accelerator it drops to just under 500rpm then conks out. We think the TPS might be a little iffy, have to check it out, haven’t had the time hopefully I’ll get to it soon and the Skyline want see a tune shop until after Christmas.
This person may be a good mechanic, but if you just ordered the unit and asked someone who hasn't been trained on the unit and doesn't know it's full features, to tune it, you are asking for trouble.
Pinging sounds like a tunning problem not a unit problem.
I would sooner consider the Power FC b4 the Fcon V simply because there are more people who know how to tune them. But i would still buy the wolf b4 either of these, due to the security feature and a few others. The only thing the wolf lacks is a knock sensor, but if it is properly tunned it is not required.
I personally am still behind the Wolf, as i have had no problems that weren't related to tunning. At the start i also had some delemas, but with further tunning these have been eliminated.
Nizmokid if you didn't screw me over earlier this year i would have put my map/tune on a disk and send it to you, to use as a base tune, then get your mechanic to trim the "edges" to suit your car.
You never know when something will come back and bite you on the A$$!
Each car is different, thus needs to be tuned individually. This idle problem also sounds like the tune needs some more fine adjustment. MAP sensors are a little bit harder to get right.
At the start mine also had idle problems, but now it has been all ironed out :P.
If it's a "Plug and play" ECU, as the wolf is touted as being, then surely the wiring diagrams supplied with the unit should contain all the information needed to install the unit, and the base maps also supplied with the unit should at least be capable of getting the car to idle.... now, of course some tuning is going to be required, quite a lot in fact, but really, a decent ECU requires a tuner who knows how to tune EFI.... A "plug and play" ecu shouldnt really have any hidden features that require a specialist tuner to operate it...
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
