if they are the RE540s they are really, really old. they were superseded by RE55s a looong time ago. that could be part of the problem, they are probably pretty hard so they will still give good 'feel' but not near as much outright grip as they should (hence you won't be getting near as much body roll as you normally would).
try again with your next new set, and on the first track day borrow someones heat gun or pyrometer for a session or two and as mentioned above split the tyre into 3 segments (inner, middle, outer) and measure the temps. you will soon see how it's working the tyres.
the other question is have you done many road kms on them? cause that will definitely wear out the insides even with 'just' 2.5 degrees neg.
Hey Baron,
I did a DECA on them, about 30k's and had no noticable wear. Car was trailered down.
Car has done another 30-40 street k's since that track day as it's not really street friendly in looks or mods, street reg'd yes, driven rarely though.
I'm thinking see how we go with the next set of rubber, I'm just not keen onthe idea of learning that I have a bad setup while chewing out new semis.
Pyrometer will tell me the inside egde is hot sure, but then what? I still need some idea of what requires adjustment.
Might have to get DMS to align it at that point.
Castor should not change with more or less camber. Correct me if I'm wrong people.
Dane. +2mm rear = drift?
Not sure yet Russ, but will be interesting to see. It didn't feel super loose in the rear end at Sandown at all, but it was pretty damn slow driving so I can't tell. I was wary of it too, but I explained my issues to Traction Tyres and they recommended this so we'll see!
Dan: Will be interesting to note the difference the reduced castor makes. My castor brief is 'as much as possible'...
8kg (450lb/in) is very stiff in an S13 for grip work.
I started with 9/7kg (500/390lb) springs that were in the car when I got it - absolutely hopeless. Far to stiff for semis. Car was totally unable to cope with bumps. Dropped down to 7/5.8kg (390/325lb)and it was better, but still very hard. Car would almost skip over bumps on the high speed sweeper under the bridge at Lakeside. I'm now down to 5.8/4kg (325/225lb)which is getting pretty close to the money in my opinion. Its certainly not soft.
I run far more camber than you and a bunch of toe out and have no inside edge wear. My vote goes on the old tyres misleading you as well.
Edited by hrd-hr30
Some very good food for thought there.
Thanks as always guys, appreciate the time taken to respond.
Has my question been answered? Not entirely but I do have more things to consider and am more aware of the factors at play so we're moving in the right direction. :(
EDIT: Coz I'm the mad typo king uleh~
Edited by ActionDan
What Jamie was saying is that more caster = mroe neg camber through cornering = more load on the tyre shoulder, more heat, more wear etc.
Yes that is correct. Dynamic camber is a good thing so you're gettting more camber when you need it and not when you don't (braking).
The thing you need to be carefull of is the hype the drift %#^$ers come up wtih in regard to castor. Yes it helps. But at small angles and in small amounts of lock it is far less influential than people think.
Yeah. Castor is good for drift cos it helps the steering return to centre when doing mad snakies. :D
Drift can get out...
Cmon man. Drift is sik!
  • 3 months later...
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
