Now that I think about it I am not even sure they have a drivers airbag. Half of them have steel wheels & povvo pack brakes. On the upside you get no active rear diff & a decent set of ratios in the 5 speed box (Not 6) plus some other fun stuff.
At the end of the day they come like that (stripped) so people can use them as race/rally cars. for which you don't need compliance. Which begs the question - what do you want it for?
The problem is the airbags. The 5 has neither a passenger nor driver's airbag, both are required for 1998 and later models. On the 6 airbags were optional for the RS's (don't quote me on that, I've simply seen RS's both with and without), and I think from 7 onwards the RS's had dual airbags but again not 100% on that, I've never really looked.
Take it from a former evo owner you would rather the GSR. the RS is a pov pack where everything is optional, meaning the chances of having aircon or power windows are only a touch higher than the brembo brakes that are all factory options on a GSR.
Buy a GSR :)
Yeah I've had 2 evo's before. The reason I wanted an RS is that they're tuffer and I wanted to be a little different. The few I've seen were street trimmed, carpet, air con, brembo but no recaro's on elec windows.
I'll have to stick to a GSR I guess or get an ADM Evo 6.
  • 3 months later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
