You guys can wait your 3 months for 5970 waterblocks but I've already got my GTX295 Co-Op installed :D
Yes there's always better, but it always costs more. I think I have spent enough.
for now...
  • Replies 115
fair call,
I am looking at also getting a bigger monitor and always had concerns with buying anything that requires a plug from the US.
Is it just a US power point adaptor that is required? or does anything else have to be made.
reason i ask is i race RC cars at a state level and a lot of the elctronics we cant get from US due to incorrect frequencies etc so i also carry that aspect on from ordering anything from the US
Newegg prices are good but as you mentioned you cant get them to ship to Oz is that right?
Yeah they won't ship to Aus so I went with a local distributor. CBF with all the hassles that involves. They have good gear though, and decent stock.
I don't know about the power thing exactly... I know their plugs are physically different and their voltage runs at 110 instead of 240... Most hardware has a convertor that can take either though.
A US website that one of the guy from work here uses all the time is www.provantage.com Some prices are comparable with Newegg.
I dont entirely agree though with the posts mentioned before about us being ripped off and HEAPS cheaper in the US.
Honestly, please prove me wrong as I wanted to use provantage to get a gfx card but by the time courier costs and the dollar difference is added it is only a $30 saving when i was looking at a 4890.
Plus i was always told with electronics if it is not a huge price difference buy local as it is much easier to organise returns etc. The further away the harder it gets.
Again if i am wrong please let me know as I would love to find some good cheap gfx cards :-)
Was there ever a shortage of 4890? Were they ever selling for DOUBLE the USD price while our dollar was over 92c?
Most if not all power supplies are now auto switching b/w 110V and 230V
Edited by DivHunter
I think one of my SSDs is farked... BIOS doesn't label it and when setting up Windows 7, it thought the drive was 950gigs... I wish.
I'm going to check it more tonight (didn't get much of a chance last night) then probably send it back and sort out the RAID0 at a later date :blink:
It's all so I can play solitaire in the best res.
I got it to work... sort of... it comes and goes. all up I have 5 HDD's, and 1 cd rom. at the moment, one of the SSDs isn't showing up and neither is the cd rom. Depending on where I plug them in on the motherboard they appear and disappear... It's not vital at the moment as I'm waiting on a 3.25 drive holder to turn up so I can mount the two SSDs...
I'll sort the RAID0 out then.
Ive had similar issues with my mobo and RAID0 and other drives now showing up.
Worked it they need to be in a certain order.
I'll look tomorrow and let you know how mine needed to be (about to head out), took me a while to figure out as the manual had nothing about it.
Once i plugged them in a certain order to the SATA ports = all was fine
yeah I dunno, I used all the sata cables I had
I had a feeling they would nee to be in a certain order... I need to figure out what it is though cause in order to get to the sata ports, I have to take the vid card out... then I can't test the cards without the vid card.
I'm having massive problems with Borderlands too... Steam thinks it's not installed and it's a 7 gig download...
If you are trying to do a raid setup on the mobo, it depends on if the mobo has onboard support for raid and sata drives, if yes, you plug the two hdds into the different colour sata ports onthe mobo usualy blue or orange, and when installing win7 and sata drives, make sure ahci is turned on in the bios, but win7 sata drives blow, so use the newest intel ones, just have them on a flash stick.
and i read the first post, not sure if you have a computer yet or not but..
I basicly use mine for the same you will be using yours
After Effects, maya 2009/2010, z-brush, ect..
what i have is, and its cheap now to build...
i7-920 @ 4ghz on true120e, makes sure you get a d0 stepping as they oc the best, but the c0 are fine for 3.7/9
gigabyte x58-extreme (i think they have the UL something now, basically the same without all the cooling bits)
2x3gb kits of of G.skill 1200ram so thats 6x2gb sticks, so you will get some some 3channel ram happening(i started with 6gb and it was fine, but when i began rendering for print, and 1080p and 4k video res's the extra ram helped, but i had to lower my clock speed to 3.7)
cooler master 1000w psu
5x1TB hhds storage and windows
2x60gb ssd one for windows and programs, and one only used as a maya scratch disk
blu-ray drive, $120, but you dont really need that, but backing up 25gb a disk beats tons of 8gb dual layers
graphics card dosnt matter for maya as its only doing basic open GL rendering in real time, unless you have an extremely heavy scene and then you would need somthing like a quadro FX, but i have 2x4870s in crossfire, they are cheap now and good enough for maya.
case, wateva you want, but you want somthing big, i have the cosmos S
all that now from msy, minus the case bluray, ssd's and lots of hdd,s should be around the 1900 mark or less, plus the new 6cores come out next year so you can either wait or buy now, dosnt really matter tho as the i7 socket will be the same so you can always upgrade..
and just so you know how much quicker the i7 is, my old maya rig was e8600@4ghz, 4gb ram, rendered a 300dpi a3 print in 26mins, the i7 stock did it in 8mins, and then 6mins when overclocked.
and you want 2x24s or even 3, i have 2x23s and 1x24, the 24 in the middle 23s on either side, you need multimonitors to speed up the maya work flow, you can have your main window in the middle and then top/side/wateva view on another monitor, same with a huge custom shelf, all depends on what you are doing tho.
good luck, hope that helped.
oh, i noticed your budget is $1500 so...
i7-920 $389
EX58-UD5 $364
1gb 5570 ati card $199
1TB Hdd $97
6gb gskill $175
1000w psu coolermaster $295
res use your old case and dvd drive and hdds and there you go, pretty neat system for $1500, everything is from msy.
f*cken awesome! thanks mate!!
i've since found out i can order through my parents company, but not like the main company, some spin-off one so i can meet the 50% rebate requirements, so $1900 is fine.
I was actually looking at the i5 750 i think, because i read that can be oc easily and relatively safely. But if i can get all the for $1900 then sweet.
Sounds like you are pretty damn serious with your work... got a website/folio to have a look-see?
so let me get this straight, you have...
23" x 24" x 23" - that's the monitor setup? dear jeebus...
with the 50% tax thingy... i was contemplating getting a 30" dell and then maybe a 20" a put that in portrait mode?
for the work you do, would you recommend a 24 x 24 setup (don't think i'll go 3 monitors) or perhaps 1 x 30" or 30" with a 20"
EDIT: are the SSD's a necessity with Maya or say After Effects?
Dont get an i5, they suck, and they have no Hyper Threading (i think thats them, or the i8) but they suck anyway, because they are just old tech sold as new plus they have some wack new socket that will be outdated soon, and yeh not too serious yet as im still in uni, but i have some unfished work on my youtube channel that i use for my lectures to give me feed back befor i hand in/fix up you can check it out here my youtube channel
but yeh, i have 23x24x23, middle screen is the good samsung, the other too are soso asus monitors, but still good
with the monitors, it all depends what you wanna use it for, imo portrait mode sucks balls as everything is widscreen these days and i dont really see what you would use it for, it would suck in maya as the tool bars are on the sides and top.
I say get 2x24 that would be a decent setup, but the bigger the monitor is the easier its on the eyes, when i have the moolah, ill get a 26 or 30inch because working in maya and ae for long really gets to you.
but what will you be using the computer for?
it should be free to re-download, unless you dont have the bandwitdh
I don't see tilatech.com having ANY video cards, let alone stock of the 5970... So with the fact that it's more expensive, f**king massive, doesn't have many or any watercooling blocks, and that I can't even find one to buy, I'm going to stick to my 295 choice :(
Which by the way, was waiting for me at work along with everything else.
Hello, we have 5870 Radeons in stock and 5970 Radeons in stock now. We do ship international via UPS, but we recommend our USPS service because it is quite cheaper in comparison. We also ship custom desktops and can custom build to your desires. Please feel to shoot us an email at [email protected] for shipping quotes for international orders and if you have any questions.
Edited by TilaTech
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
