Trying to get my RB20det gtst4 r32 to start this morning.
I have never got it running since I bought it.
There is supposed to be nothing wrong with it as far as I know although, we found there was no spark. So first we replaced the ignitor and that seems to have fixed our spark problem but car will still not start.
The car is not firing AT ALL.
Definitely getting fuel, we saw it squirt out the chassis rail lines.
Ecu is spitting code 13 and 43.
Just don't know where to go from here.
We will reset the ecu and see what happens
Please help :D
https://www.sau.com.au/forums/topic/298774-my-freaking-rb20det-wont-start/
The fuel needs to come out of the injector, not out the chassis rail lines.
Are the injectors working? Can you hear them "ticking" while cranking?
Are you trying to start the engine with a healthy battery? The ECU needs something like 7V to stay "alive".
Do a compression test on the engine.
The meaning of the error codes. 13 = "Engine Temp sensor" - break or short circuit in the sensor system. 43 = "Throttle sensor system" - disconnection or short circuit in throttle sensor system. The errors are persistent, they exist for about 50 starts. So reset the ECU, then immediately check for errors.
First thing I would check are......
Do I have pressure in my fuel lines
Are my injectors getting signal
Is my CAS in the right spot
Is my fuel shit and old and needs replacing
Even if you had half decent fuel and the CAS was a little off it would start but it would run like crap. Does it try and fire at all or do you just keep turning and turning and getting nothing?
Definitely have pressure in the fuel lines.
We listened to the injectors and we could hear them ticking.
We are going to try another CAS tomorrow but have inspected it already and seems ok.
Starting to think maybe something with the fuel system isn't right.
Basically just turns and turns till the cows come home and nothing exciting happens :)
tip.
unplug the ecu from the loom, and then put it back in but this time make sure the plug is sitting all the way into the ecu. screw the 10ml bolt a few times and press both sides of the plug and keep doing this untill its in correctly.
If the injectors are ticking, then the CAS is working (ECU gets a signal from the CAS then calculates when to fire the injectors).
Are the fuel lines on the right way? Also, pull an injector and watch the spray while you are cranking the engine (sit the injector in a glass jar or similar). Engine might well be flooded. Pull the spark plugs and dry them off. Also, try starting with WOT.
The errors you are getting will not prevent the engine from starting.
With the ignition on check for battery power to coils (whilst you are at it check AFM and CAS as well). If you have verified you aren't getting any spark I would focus on the ignition system. It is a process of elimination.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
