im trying to find rims for my black r32 gtst
and im not sure what ones i want
ive got the black theme going on at the moment, black car, dark tints, black head lights.. so i need black rims
so im heading towards satin black
i want 18 inch and hoping for a fatter rim in the rear
i was looking at the bsa replica TE37's (satin black with red lip) but apparently they dont have a fatter rear rim
im looking at spending around 2500k - 3k
any help would be awesome, as this is the right place to ask
so can you guys post up some rims of what you reckon would look good
Thanks Ash
https://www.sau.com.au/forums/topic/298886-what-rims-to-get-for-my-r32/
for 2.5-3k mate i'd be looking into some quality second hand japanese rims - as apposed to brand new copy rims
keep an eye on the forums, or if that fails there are a few brokers who will be able to help you with yahoo jap :laugh:
I dont think the GTC will suit 32 at all. Reason being GTC looks too fat for any sleek cars. Prefer multi spokes (more than 5) with dish for sleek cars. Look at Colin's 32GTR with XD9. :laugh:
http://www.skylinesaustralia.com/forums/Wh...tr-t269174.html
I'll pimp this one for ya Tristan.
Oh yea. For that price. Dont bother with copies. Just get 2nd hand stuff and be on the look out on the for sale section. I got my LMGT4 for 3.4k with tyres.
keep an eye on the forums, or if that fails there are a few brokers who will be able to help you with yahoo jap :D
Quoted for truth!
Here is an example from Yahoo Japan
18" x 8" +40 Front
18" x 9" +35 Rear
Estimated total price delivered to my work in Warriewood via sea (assuming it doesn't go any higher than minimum bid...) is $2,633.68
Stronger, lighter and hold their value longer than anything from Tempe ;)
EDIT
I probably should add that I found these via Import Monster, I am not a import broker :laugh:
Quoted for truth!
18" x 8" +40 Front
18" x 9" +35 Rear
Stronger, lighter and hold their value longer than anything from Tempe :(
EDIT
I probably should add that I found these via Import Monster, I am not a import broker :D
party time! :laugh:
thats the idea!
however i'd argue those widths/offests aren't baller enough ;)
gtc's on r32 = epic fail
work meisters on r32 = epic fail.
black te37s on r32 = major win!!!
volk ce28's look phat too.
for the amount of coin you are looking at spending, i think you could easily get some second hand if not new jap rims.
and on a 32 17's look big if you have low profile 40 series tyres.. saving you some money over 18's.
Like I've recommended to anyone thats on a slightly lower budget. Get the Gramlight 57d. Price isnt bad for a Ray. But if I'm you, I'll keep a look out for import monster's website/post or just the forsale section.
For $3K why not get used TE37s of any colour, and then powdercoat them in black? Hopefully you can then find some in a proper offset and width, rather than the weaksauce ones that replica wheels inevitably come in to fit FWD econoboxes.
I've seen quite a few on the Yahoo! Japan auctions.
For $3k you can buy genuine & new - import them but be prepared to wait a while to receive them.
Rays CE28N in bronze or titanium silver.
CE28N:
OR
Rays RE30 in any of the three colours available - bronze, chrome silver or (for another 5000Yen - ouch) formula silver with a diamont-cut rim.
party time! :blink:
thats the idea!
however i'd argue those widths/offests aren't baller enough :D
i agree bro... to many skylines with shit wheels to many with pimp wheels and fail offset / width and a very little selection with fitment.
for a gtst
go a 9.5-10 on the rear. 9.5 with a 225 or a 10 with 235 say like -1 camber with some guard work = hellaflush
9-9.5 up front with a nice offset like +15-17 with say a 215 to 225 will look good to.
for your 2-3k you can easily do that
Edited by 32_Dave
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
