SLY33 has come along way since the old TORANA days.. hahah everytime i see him, he always has a new girl and the same WIDE smile... STUD!
HAHA, nah its just that girls are always changing their hair colour these days. Same chick different day :rofl:
I havent come all that far dude, last 2 nights ive been cruising in the GUZLER! Old school style! I miss the rumbling and the avgas fumes...!
seen her around... she looks ok...... but then again, sly33 is pretty quick with the gals!! :rofl:
dude you'll give me a bad reputation! and besides i can go nearly three minutes these days! :wassup:
you're right you haven't had a proper look :Oops:
but you are in luck, she puts out to pretty much anyone :wassup:
/rant off
haha, you girls crack me up! Like i said, i havent had a propper look!
Miss_Nismo, i dont put out to pretty much anyone! (what has N/A been saying? :cheers: haha), i just wondered if she was hot. When are you coming for a cruise with me? -but im very superficial so you have to be hot, just ask N/A :D
Enrico, you can have my old bikini girl avatar if you want it!
  • Replies 425
PS, dont prefer imported girls myself... and im half import!@ :cheers:
on the topic of this thread though, i saw a yellow 180sx, may have had a black roof and white rims. Pretty sure i remember Viva garage stickers on it. It was on anzac highway, he wouldnt run me.
I know you prefer the LOOCALLL stuff essaee.... That yellow 180 looks pretty good.
He works wit me, dont know him though, it has a s15 front with sil1580 plates. sprayed it him self.
the guy that owns the morpowa yellow 33 told be it would make about 350rwkws. I wasnt sure to believe him cos he was only using a relatively med sized turbo. cant remember what type it was. Also at that time, the car was in pieces, so not sure if its together yet.
they're starting work again on the yellow gts at morpowa this week, had been put on hold due to alot of work going into the lancer at the nationals.
not an import, but funny anywho... saw a silver VT commy, dual mufflers and chrome rims, with the number plates RIMJ 08
SOMEONE TELL ME THAT ISNT A GREAT CAR FOR UNDERCOVERS!
I saw a white 33 (with Jap stickers on it, white mags and a black GT wing) on the back of a trailer on Lower North East Rd this arvo - it had a nasty bingle on the front end :)
ahh ya i saw that one.. its at provident crash repairs atm.. front end damage looked pretty bad!!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
