haha dont hold back :(
i cracked up when i read this but it is great advice nonetheless
the way i see it, that response from brada31ke70 is like handing someone a $1000 invoice..... do it and its gonna cost you a crank grind, engine flush and new bearings... plus all the relevant labour...
Took of the oil hose to oil cooler, the one that goes the CORRECT way :D to oil pump. Got ~0.5 liter in there while cranking the engine backwards. It sucked the oil straight in. Connect hose back to oil cooler, and behold oil poured out at the turbo oil feed after 10 secs of cranking. ;):D:D
thanks for the help guys! ;)
good to hear mate!
Yes i agree with URAS, get into it, i started mine and drove to petrol station and drove straight out for a road tune on 12psi and was reving it as per normal straight away (well about 15km in oncei got to our tuning location), the thing has done 1200km now and leakdown and comp is spot on, with zero blowby. I kept the run in oil in up to 50km and changed it for new run in oil (same stuff just new batch) until 1000km even though i was pushing the motor hard upto 20psi boost and redline on lots of occasions.
I also plan just to warm her up, check for leaks etc. and get out on the road for tuning. Will only be running ~10 psi boost. After first day which will be about 1 hour total driving i'll change oil. again to mineral oil, and drive with that for the next 1500km.
Luckely i have the vi-pec so it will be a walk in the park to tune in. :-)
I'm a little excited about the difference in combusten if any..?? I have mounted a exhasut temp probe to each cylender. I'm using a copy of the greddy intake manifold.
dont let it idle on warm up...keep varying the throttle...the first 20 mins are vital.
and the rest uras. 1k would only apply if the owner did the r&r as u stated
yrs ago i used to read what body builders would do to get big, end result i have injured my back...good analogy?
roids make ur back sore? :down:
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
