Hi guys,
http://cgi.ebay.com.au/DYNOPOWER-PERFORMAN...=item4144a3a9c4
i saw this performance chip on Ebay not long ago and had a read of it. It seemed to good to be true for its price..
What you reckon?? or has anyone tired it??Would it affect an N/A's performance once??
cheers
https://www.sau.com.au/forums/topic/299045-performance-chip/
DONT
BOTHER
110% agreed, dont waste your time and money
do what 99.9% of everyone else does, and that is to go and get your car tuned, by a professional, to take in account every nuance of your own particular cars features and limitations
it'll be safer (for your engine), more powerful, and better for the environment (and your long term petrol costs)
If you're up north, road and track dyno, morpowa, willall and horsepower in a box are available
if you're down south, southern hitech dyno, turbotune, graham west can all do the same job
I prefer road and track and southern hitech cause I know both of the guys there but call around and see which one can fit your expectations the best
-D
AS IF IT DOESNT WORK! i bought one of those chips and put it in my car and it made it HEAPSSS QUICKER! it looks like a scam but its not it fully works!
never said it didnt >work<
it just doesnt work >well<
Unless of course you're running 100% stock components, in which case its probably not too bad - but who has 100% stock everything? Just about every car that comes into the country has aftermarket induction and exhaust
-D
ahaha i was just bull shitting... as if you fkn buy that piece of shit chip LOL looking at the add looks dodgey already ahaha
f**ks sake kiet
i know you're a dickhead
but misleading a guy whos asking an honest question is the mark of a dog f**king son of a bitch
pardon the f**king french, but you're an irredemable wanker
-D
Yeah stay away from them, like ben said better off getting your car tuned properly. Every car has slightly different parameters, therefore no one "Magic Chip" can be classed as a reliable form of tune upgrade.
that isn't a chip as such, it's just a resistor to play with the AFM signal and lean out the mixtures. And since our cars were actually tuned for 100RON jap fuel which we don't have, so we are stretching our mixtures already on the 40 degree Australian summer days. Another thing that points to it not being a chip is that they sell them from R33's which are fairly unchipable (well for under $800-1000 anyway).
Edited by D_Stirls
^^ hahaha the only person in the thread to actually read what it is
its a cheap knock off of a fuel cut defender lean you car = more power then bang
so in short YES it will work but is it really worth it ..... prolly not
f**ks sake kiet
-D
If someones got to open a thread to ask a question whether an eBay chip works or not... then may god help us all. :)
Skyline ECUs are fairly efficient at making power (a touch on the rich side). But it's a N/A engine with turbocharger-like compression, unfortunately all you can do is supporting mods, high flow panel filter, exhaust, cold air intake etc for small gains. unfortunately you can't just magically pull power out of your hat, unless you go forced-induction.
I've looked into these magic chips in the past when I owned a commodore, I concluded they are just resistors to make the engine think it's running colder than it actually is, permanently making your engine run alot hotter than it was designed for.
  • 1 year later...
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
