Was a great day, met a few new faces.
Vince, that car of yours is f**king hot.
A certain R32 and R33 truly showed that 400 is the new 300...
Congratulations all. Will definately go next year.
  • Replies 95
yeah as dion said some awesome cars on display.....i was a bit :blink: when my 33 only made 203 rwkw.....shaun said it has boost issues....the leak may be a factor.....time to get things sorted out before track day
The imports have taken the title for a second year with a sizable number;
Domestic Total : 2034.9 rwkw
Import total : 2919.1 wkw
Individual cars;
Import Adrian 432.0 R33
Import Andrew 421.7 R32
Domestic Dave 395.4 VZ
Import Vince 360.9 R33
Domestic Phil 339.7 XB
Import Luke 311.3 R31
Domestic Paul 310.3 VE
Domestic Brad 257.0 WK
Domestic Brendon 219.8 VX
Import Chris 203.6 R33
Domestic Shaun 194.2 VZ
Import Nick 191.0 R33
Import Todd 188.1 Aristo
Domestic Lee 184.5 XW
Import Kaits 174.2 R34
Import Mark 145.4 Chaser
Import Daniel 143.4 180SX
Domestic Travis 134.0 EB
Import Ryan 120.7 Colt
Import Kevin 119.8 Stagia
Import Rob 107.0 R31
The skylines really boosting those import numbers.
Thanks everyone for a good day and I look forward to see you all next year!
Note: Gary, I do not have a score for you. Can you please email me. :blink:
Thanks guys for letting me just show up and run, was glad you moved the date, was away and couldnt make the original date!
was awesome to crack 400, bit of fun trying to keep it on the dyno, nothing a few people in the boot couldnt fix!
nice and lean, couple more psi and a larger catcack has released a few more pony's me thinks.
Bloody good work from Adrians beast - what a number from a stock motor!! Happy with my number especially on pump fuel and can't wait to convert to E85 and crank some more boost into it!
LOL, how much leaner do you want to get Adrian.....that corn syrup must be good gear to allow you to run those AFR's
awesome power.....and did I hear right, still running the stock pistons & rods? :)
I know, I know, I did wind bit too much boost in it, normally run it around .85 lambda which sorta works out around 12.5 in petrol afr's
yeah its still all nissan except for a acl metal head gasket.
A huge thanks to all the skyline guys that entered. Huge numbers, really impressive stuff.
We'll be back next year with a slightly improved format; later start on the day and a car show on sunday!
See you in a year! :)
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
