my GTR 32 has new rims, which i will have on my car when it goes through regency for a full inspection ;) , the size is 17 x 9 +15 offset , stock rims are 16 x 8 +38 (please correct me if wrong) stock track width is 1480mm , the maximum allowable track is 26mm above stock , can anyone tell me if my new rims, track width is illegal. 255 /17 rear , 235/17 front . Or lend me a set of stockies in Adelaide for the regency visit ........... cheers
https://www.sau.com.au/forums/topic/299293-offsets-track-width-and-regency/
while im not an authority on rims, i believe that the max upgrade from a stock 8" wide rim is 9" on both sides, making your wheels OK. I dont know anything about offset however. I await scandys or dales input on this thread cos they seems to be the two most wheel savvy folks
-D
wont pass. your 9 +15's bump out the track by an additional 36mm per side over standard. the maximum amount permitted by adr's is about 13mm per side (or, approx 26mm per axle, as you said).
Edited by scandyflick
  scandyflick said:
wont pass. your 9 +15's bump out the track by an additional 36mm per side over standard. the maximum amount permitted by adr's is about 13mm per side.
thanks for the info i will need to get my hands on some wheels now ?
you know the widths and offsets of your wheels? easiest/fastest way to check.
if not, bust out the measuring tape and measure between the centre line of the tyres.
i just measured mine and got 1522 mm, stock should be 1480mm + 26mm max =1506mm ;) which means its over by 16mm or 8mm 0n each side, is this worth worrying about .
lol. glad i wasnt the only one thinking that.
  blingtr said:
i just measured mine and got 1522 mm, stock should be 1480mm + 26mm max =1506mm :laugh: which means its over by 16mm or 8mm 0n each side, is this worth worrying about .
probably. depends if the inspector you get got a blowjob that morning or not. you can chance it if you want, but getting standard wheels and fitting them just gives regency one less thing to pick on you about.
  blingtr said:
my GTR 32 has new rims, which i will have on my car when it goes through regency for a full inspection :laugh: , the size is 17 x 9 +15 offset , stock rims are 16 x 8 +38 (please correct me if wrong) stock track width is 1480mm , the maximum allowable track is 26mm above stock , can anyone tell me if my new rims, track width is illegal. 255 /17 rear , 235/17 front . Or lend me a set of stockies in Adelaide for the regency visit ........... cheers
Stock 32GTR wheels are 16 x 8 +30.
+17 is the lowest offset you can run. Width is irrelevant in this case, as the offset is the only part of the wheel specs that effects track.
  scandyflick said:
call wheeljerx/adelaide tyrepower/adelaide radial/jap import spares/adelaide jap and see if theyve got a set of passable stockies they can loan you.
:P just today i bought four GTR 33 stock rims which are 17 x 9 +32 offset , i think i got the offset problem sorted now ,but the rims come with 2 different sized tyres 215 front and 235 rear is this ok on GTR or do you need all 4 the same to pass inspection ! thanks
  blingtr said:
GTR 33 stock rims which are 17 x 9 +30
fixed :P
How GTR rim specs could be so unfamiliar to people on a Skyline forum revered for it's overall technical knowledge is beyond me.
Edited by AndrewJZX100
  AndrewJZX100 said:
fixed :P
its called being a noob :P
  AndrewJZX100 said:
fixed :P
go do a skid you homo.
:P
