I spent the last two nights working on the GTR:
1) Removed all the recirculation piping right back to the turbo inlet pipes, and blocked the holes in the rubber inlet hoses. It was previously blocked off before the splitter pipe in front of the rubber inlet hoses (I have an atmo BOV, so no need for the recirculation piping)
2) Moved my boost solenoid to a better location (slightly longer lines)
3) Fitted up all the factory breather hoses and PCV valve
4) Cleaned the AFMs wiht contact cleaner
Started the car up tonight, it ran fine for the first KM down the road, now it runs like poo! :blink:
stutters and barely holds revs before stalling.
What have i done?????
*worried*
https://www.sau.com.au/forums/topic/299580-help-what-have-i-done/
not plugged in the AFM's properly... clean the afm plugs with contact cleaner...
hmms, i did tape up the connectors a bit, and did push them in till they clicked... would that explain why it ran fine for the first 1km down the road tho?
hmm, maybe one of the parts u blocked may hav unblocked somehow and caused an intake leak,,just check them all again,, and did u make sure ur afm was completely dry before putting it back in?
boost gauge is only reading -15psi instead of -20 vacuum, so there has to be a vacuum leak somewhere. will suss it out better tonight.
well, still no luck after another 6 hours spent..
I have:
checked all intercooler hoses/clamps
checked all breather hoses/clamps
checked my HKS BOV
checked all intake hoses/clamps
re-cleaned AFM elements, connectors, and even took the covers off to look for dry solder joints
re-fitted the recirculation piping the way it was previously.
still idles rough, and hunts for revs at 1500rpm, and when i tap the accelerator, it stalls
anyone got any other ideas? its driving me nuts, and i want it running for the weekend!
I have:
checked my HKS BOV
have taken it back to Simon at Morpowa or atleast rung him???
im sure he be able to fix it
he tunes my 33, had an idle problem ages ago n he managed to track it down
Sounds like dry solder joints in AFM, did you dab some new solder on while you had the lid off? You wont be able to see the crack in the joint, its usually where the plug comes in.
A vac leak shouldn't affect driving too much, just idle. You can sometimes find them by spraying aerostart or carb cleaner around the plenum.
I can come over with consult/laptop to have a look
have you tried simply re-setting your ecu (ie disconnect battery for 10mins, pump brake a few times)
atmo bov - why? the stock gtr bov should be fine tbqh.
hey mate
car is sitting at JMS for Brady to look at
haven't reset the ECU no. (its a PowerFC)
As for the BOV, I had to remove the stock ones because they were in the way of the front right wheel on full lock...
Plus, I save a heap of weight over the front wheels by removing nearly 10 kilos of cast alloy pipes, recirculation pipes, etc.
is the engine check light ON? if so, its a sensor (ie AFM dead or unplugged)
check the hand controller, ETC SENSOR SW CHECK, anything odd?
if all ok, its a cooler pipe / joiner
would explain psi then running like 8psi
problem all fixed and rectified.
breather hoses were affecting AFM readings, causing an epic fuel overload, and fouling the plugs. new plugs, and i bunged up the breather hoses and it will see me till a retune!
thanks for all the ideas guys! much appreciated!
Nigel
Nigel
good to see you've got it sorted. just out of interest.
was there somethign wrong with the breather hoses themselves, or were they fitted loose or something..
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
