Wakefield + R35 + Willall Tune + Slicks = ?
GGTTRR and I were at Wakefield Park today testing out the new Willall R35 tune, in addition to some Michelin and Dunlop slicks (2nd hand)...
Cars both run a mid pipe, tune, slicks and aftermarket rotors/pads ONLY....
Result:
Marek ran a 1:03.79
I ran a 1:04.00
I can't believe how quick these cars are, it's insane for a car driven to the track (in leather clad and aircon comfort) with essentially minimal mods. I can only fathom what these cars are capable of with some serious setup. You have to remember these cars weigh 1750kg....
Congrats Marek, great driving man.
Edited by LSX-438
https://www.sau.com.au/forums/topic/300165-wakefield-r35-willall-tune-slicks/
  • Replies 67
Result:
Marek ran a 1:03.79
I ran a 1:04.00
Thanks Dunc
Clearly the Dunlop's are 0.21s quicker than the Michelin's
Great driving guys, duncan which pads & rotors, where do you get em and how much.
Dom
I am running Carbotech XP12's with AP Rotors
Marek is running Endless MX72's and AP Rotors.
I've had a quick drive in Mareks car and the MX72's feel better to me. I will not be buying the carbotechs again... I am very impressed with how much the endless pads look after Mareks discs too - they still look like new after two track days.
Forgot to mention that mine is a tarmac rally and occassional track use only vehicle. IE not used on the road.
would that nake a difference?
I really dont know anything about the demands of tarmac rallies (they scare the bejesus out of me btw!!) so i couldnt say, sorry mate. There are a few people on here who can help though, i am sure.
Result:
Marek ran a 1:03.79
I ran a 1:04.00
Unbelievable times guys. Well done! Where are you sourcing your 2nd hand slicks from?
Awesome work guys, thats motoring in anyones book! Great to see Marek out there and kicking some serious butt too.....looks like a two way fight for the title next year if ever I have seen one :)
That's the plan Martin, I don't want Duncan to have it all to himself :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
