so, firstly, i know this in the local section. secondly, i have already searched, alot.
anyway, having some troubles with my car. basically, driving along, engine cuts out. has happened four times, twice i had to push start the car, once it started fine and the other it would do either until about 20 mins later when i tryed and it worked.
3 times the engine completely cut out - no revs or anything etc etc when the engine turns off. another time it felt like the engine cut, got no reponse from the accelerator or steering but the revs were still up. they eventually dropped down and stalled, but i thought id was a bit weird driving along with the engine going but no response.
so basically i have a few ideas, but no real idea. from what ive read could be aac valve, bov, and i reckon it could maybe have something to do with fuel?
any other ideas?
https://www.sau.com.au/forums/topic/300201-car-issues-no-idea/
have you looked at the AFM and do you have an immobiliser installed i had one that broke and had the same symptoms as you are having i had it removed and then replaced with a new one works great could also be your ECU or Alternator
if the car is actually running fine while its working its more than likely an electrical problem. if its got an immobiliser than you should have it removed and buy a new one as its probably cutting in whenever it feels like it...
Although intermittent Gus take it to the Pro's. Yes it will cost unfortunately.
Were all guessing and it could be many electrical things. (dicky ignitor perhaps?)
It's too scary to be going fast around a mountain corner when the engine cuts out. No power stearing and near nothing in the brake department. If your not right on the ball a heck of an accident waiting to happen.
Cheers
S!N
Another vote for immobilizer here.
Another thing, is there a chance that maybe the plug on your ignitor box at the back of your coil packs is loose?
Does the car die completely or is anything still running (i.e. fuel pump)?
1 vote for CAS.
Give me a buzz if you want to test it out. I should have a spare CAS you can test out but I want a retainer because someone else on here didn't end up returning my ignition module.
Beside that, I have a few other spares that you can test as well.
happens when im slowing down coming up to a corner
I'd agree with Sin. Go to a mechanic, that 5h1t could get you in a serious mess if it happens at an unlucky time. Extra to previous suggestions, I'd get the Throttle Position Sensor checked. Mine used to stall when I was rolling up to intersections or travelling through slow traffic at low revs. It behaved fine for the mechanic until he gave it a whack with a (I assume padded) mallet, then it went haywire/stalled the car etc. Hard to find, relatively cheap to fix.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
