  • Replies 3.6k
Posted Images
was watching top gear on tv last night and they had coulthard farking around in a 05 RBR car and man they look and sound great. I do miss the old V10 days. they were a sweet engine. The car looked great too. the cars look a bit cheap these days by comparison. :cool:
Probably old news to most now, but the other night I watched an Autocar vid where Chris Harris drove an '06 Red Bull at Silverstone and reckoned it would waste a Veyron with only 1/5 throttle. First time he really gets on it he says "it makes the Buggatti feel like a Mazda 2!"
if you can turn passenger laps in that thing for $99 count me in.
in other news I will be in europe later this year and currently deciding between Spa (end of aug) or Monza (early sept). Monza will be easiest as it already tees up with some plans and I'll be in italy at the time. But Spa is just another level all together but it would mean having to reschedule things a bit and mean going to belgium which is a bit of a punishment really. lol. anyone seen "In Bruge"? lol.
currently leaning towards monza. it will be cool to see all the tifosi out in force. I wonder if any of them still have love for schumacher?
on the plus side if I do monza it means before it I can scoot over to germany and get some laps in on the nurburgring. yeah baby!
oh, and I've just made the choice. fark watching at spa. I'd rather fang something around the 'ring instead. I may even forget going to the monza gp too and use the money for another day of ring and then just watch it in a bar in italy somewhere.
very excited about doing the ring. just need to decide what to drive?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
