The Redbulls certainly seem to have the most sorted cars for the Melbourne GP. The Ferrari and Merc's seem to be able to do 1 quick lap here n there but not consistently.
If Webber doesn't get a podium tomorrow he'll have blown a big chance on some good points.
  • Replies 3.6k
Posted Images
Starting 2nd and has no chance?? Hater much?
I agree. He has a better chance than everyone except Vettel. If Webber doesn't make any mistakes and Vettel does Webber can come home with the win. If he does I will run all the way from Turn 3 to the podium, possibly waving my Webber shirt.
Shaun,
Don't you have to go and bail out your hoon lover?
Baron to storm through the field and will be in the podium tomorrow!!!
Hopefully Webbz gets up, but top 3 with he and Schui, and I am happy!
P.S
Kimi,
come back now....
Don't you have to be the cop on a Shooey and Webz spit-roast?
Maybe!
You keen on getting in on some Schu Spit Roast Action?
Remember the Baron is faster in his sleep than Homo-Tron is out on track!
my last post was supposed to say p_i_g instead of cop obviously
don't know if you've noticed, but Old Man Schumi hasn't exactly been setting tracks alight. Slower than Keke Jr actually
Old man Withers has been out of a car for 3 years,
I don't think he is doing too badly, seems a touch faster than Louise this weekend.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
