  • Replies 3.6k
Posted Images
Gotta love the interweb.
To make things clear.
I understand your position(s).
I disagree with them.
That doesn't make me ignorant.
My apologies. You are entitled to your opinion no matter how correct/incorrect it is.
I think you are looking at it from the wrong direction. I agree that F1 engineers and designers do not have road cars in mind when they invent a new part or technology. They are there to win races in F1 only and couldn't care less about the car industry.
What I'm saying is that car manufacturers look to F1 for ideas and new technology and use what they think can be applied to their production cars.
Whether this is purely for "fashion" or not, there is no denying this occurs.
Anyway, enough of dribbling over splitting hairs, who's going to win the next GP?
Red Bull and Mark Webber anyone?
Bernie once again taking F1 to parts of the world where nobody gives a shit. Its NASCAR country where even IRL dont do as well. What hope has F1?
Anyway, looking forward to seeing the crowd of 10-12 people in the stands for the weekend's GP. I wont dare bet who will win in the sphincter of the universe. I personally think Ferrari are overdue for a good weekend and think it will be close between Nando and RBR, possibly Massa rememberign what made him quick around there
I'd rather see them keep the classic Euro tracks than take it to places like Texas where they couldn't care less.
As much as I'd like to see the Ferrari's do well this weekend, I think RBR will still be the team to beat. Ferrari is going to try their new rear wing (from Spain) again tomorrow. External threats could come from Button and Kubica also, potentially even Rosberg and Schuey but not likely imo
I just don't understand why they didn't consider Watkins Glen, Road America, Road Atlanta or even Laguna Seca... Throw 20-30-40 mil at any of those circuits, make a few changes to the track layout, upgrade pits, grandstand and facilities... Viola! But noooooo... Bernie is a comple f*ckwit...
Webber a New hope? Vettel Strikes Back? or the Return of the Fez?
Edited by Marco-R34GTT
US GP for 2012, in Austin Texas!
Texas US Grand Prix!
Austin 3:16. Why? I don't bloody know!
I agree with the other post that the US has several worthy tracks already. Why they're building a brand-new road course in SOUTHERN America (NASCAR country) is beyond me. This will probably flop. I hope to be proven wrong, but all I can say is I'm glad it's not my money.
I do have to say, though, several of the US's top tracks would need more than a small investment to run F1. Watkins Glen and Laguna Seca, for example, would need extensive works to make FIA safety standards. There are a couple of sections of both where run-off is a major issue. Then again, they run at tracks like Monaco and Albert Park, which are as bad or worse.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
