  • Replies 3.6k
Posted Images
so... to sum up, with 3 laps to go (cause nothing is fkn happening), spa is a shit course, ferrari is a shit team, vetool is a shit head and this was a shit race.
I could have been playing a game this whole time...
Not Spa mate!!!! :(
spa is shit?!?!?!?
its home to probably the best corner on the calender
and which is that?
My favourite would have to be the 4 corners joined in the sphincter of the universe (I think) that the RBRs could run flat out. Exciting if it's done right, easy to do wrong.
You deserve everything you DONT get Massa
if you sign up to be a bitch then thats all you deserve, i hope they tell you to move over for every race for the rest of your career, i fucking hate you
team jihad can suck a dick, i hope you all burn in hell
the sooner they punish you for this the more faith we'll all have for the new FIA
ah well, woulda been better if the RBR's finished ahead of the Mclarens in terms of making the WDC even more interesting :(
keeps things spiced up at least.
edit: meanwhile, you think if Webber got a similarly veiled message he would "understand" it?
Edited by mickey
and which is that?
Eau Rouge is all that and more. It's had some epic accidents and overtakes over the years. Compared to Eau Rouge, Turn 8 can suck it
I think he'd suffer 'radio failure'
i sat at turn 8, and its pretty epic dude
they scream around it and you cant believe how sharp those corners acctually are
its maximum commitment for at least 6 seconds, very impressive stuff
Have you also sat at Eau Rouge? I'd like to hear a comparison from someone who's seen both.
I'm not denying Turn 8 is a great corner, but I stand by my claim that Eau Rogue is more spectacular to watch and a bigger challenge for the drivers.
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
