  • Replies 3.6k
Posted Images
if you havent got F1 2010 yet... do it!!
its bad ass
werd. great game, a couple of irritating bugs but hopefully they patch them properly and not do what all game makers usually do and just ignore those who paid money for the game and start working on the next title...
we have a hotlap competition at work and nominate a track each week, best time in time trial mode gets bragging rights. any car, any setup tweaks... it's good fun (specially cos I'm winning :P)
Hell yeah, F1 2010 is the bomb! Reaaaly need a wheel though, just can't get Becketts right with a controller :D
P.s. Webber will wrap up the title in Brazil. Cmon son!
Mark needs 1 strong finish (ahead of vettel) and then it all begins to look considerably better.
Indeed, and I think Brazil is just the place for him to do it, stake his claim. He drove a great race last year, and there's no reason why he can't be super competitive there this year either.
He really doesn't want to leave it until the last race. It's almost a stab in the dark as to who will win if it comes down to the final weekend, so i'm hoping he puts in a really strong showing at Interlagos.
Are you playing it with traction control off and on at least advanced difficulty?
playing with all aids off and swap between pro and elite difficulty. 1st season of 7. Driving for Lotus , Currently at monza GP leading the Championship by 5 points from webber. (using g25)
Edited by Kaido_RR
What the hell :)
Steering wheel I assume? :)
How do you tackle the kerbs so hard without having problems coming off them?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
