I have noticed sometimes the fuel gauge in my car drops from 1/4 tank to empty with the light on, in the space of a few k's. I read the v35's are having similar issues and wanted to know if anyone else has this problem.
I pulled the pump out to check but couldn't find anything obvious wrong with the sender resister.
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/
In the space of how many km's Scott?
Mine goes from 1/4 to light on after ~140kms normal driving :)
or
1/4 to light on after ~70-80kms of fun driving
I have noticed at times that the light will be on when I shut the car down, then an hour or so later when I go out again I will have just over 1/8 of tank left with no light on (nor does it come on for a while either).
Can also behave differently on different fuels.... Vpower will drop from 1/4 to nothing much faster than Ultimate.... and don't get me started on Vortex98 :ninja:
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-4991205
Mine fluctuates the whole time, not just below the 1/4 mark. It can be below the 3/4 mark and then 5 minutes later its showing just above it...
I've learnt not to pay that much attention to it - since its usually just a "rough indication" rather than an accurate measurement.
Lately I filled up when the needle was just above empty (as in very very close to the empty line), but only got 54L in. Other times its been on the empty mark and I've managed to get around 62+L in.
From 1/4 to empty I normally get around 50-80km maximum.
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-4991263
It goes down fast at the end of the tank and probably does exactly the same thing. I am not that worried as I just fill up when the light comes on.
Cheers
Andy
I tend to not pay attention to light unless i am over 400km's in that tank haha.
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-4991559
Mine drops to light on sometimes after one boot onto the freeway then stays there. If I switch the ignition off and on, its back up to where it was.
Im guessing there is a dry solder joint there somewhere, anyone know where the electronics is for the sensor? Let me guess, dash out?
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-4992088
  • 1 month later...
Lately my fuel gauge has been getting much worse. Rather than giving me a pretty close "ballpark" reading, its now often wildly inaccurate. I've seen it nearly at the half way mark after just 130km or so, then I'll actually manage somewhere near 200km before it goes below the half way mark, then later it could be back up between 1/2 and 3/4...its just all over the place, often out by more than 1/4 of a tank!
Not sure if its just a faulty sensor but its very annoying. Soon I'll be using the kms since last fuel stop to determine how much fuel is in the tank...on a 2003 model car!!
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-5056072
I sometimes get that, seems to be the carbon on the sensor wearing out as I pulled it out for a look. If you switch the ignition off and on, it goes back up to where it should be.
I wonder if you can buy the liquid carbon and repaint it...
Edited by scotty nm35
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-5056387
after fixing my turbo pressure pipe. i have been clocking 500km's easily in the volvo..
and this is with the same thirsty driving i was doing when i was getting 400's if not more pedal now i have more boost :)
?? what pipe is that?
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-5057959
rubber hose near washer bottle to plenum area..
You mean the one that goes to the boost sensor (ie. the sensor in the little oval shaped black box that sends the boost readout to the in-dash guage) ?
Interesting, I fixed that sensor a few months ago after reading how to do it on here (power connections inside it needed re-soldering) but at the same time the factory hose split and continued to split every time i cut it and re-attached it...so I've replaced it with a similar sized hose but this one keeps falling off the plenum side since there's no "lip" to hold it on. Its been bothering me in the back of my mind ever since (ie. vacuum hose off cant be good) but I just haven't gotten around to fixing it since it didn't seem to upset performance.
Now that you mention it the fuel economy could well have started to go bad around the time I fixed that sensor...was getting mid 12's (L/100km) and now its consistently in the high 13's if not low 14's... :P
If thats all it is then I feel a bit silly for leaving it so long...
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-5060142
Im guessing Angus means the 60mm black rubber pipe with the bend next to the washer bottle.
The hose you are talking about, the 3 or 4mm one will need to be replaced on most of the M35's coming in as they are very brittle. It only affects the boost meter in the dash so im not even sure all M35's have it. Definitely wont be the source of your bad economy, probably the heat doing that as the ecu is adding fuel as the inlet temps go up I think.
https://www.sau.com.au/forums/topic/300455-m35-fuel-gauge/#findComment-5060484
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
