Spotted! me driving like a grandma because my cluctch slipped to the point where it revs whenever you put your foot down! hooray! booked it in with Ed, looking at $1000 for a new Exedy clutch installed, apparently slightly better than stock. I'm not a lead foot so it should do, but ouch! $1000 so close to christmas! i could cry!
Sounds like me!!!
My clutch is ***ced.... Does the exact same thing... Im after the Exedy Ceramic clutch, got prices for just the clutch.. comes to around $1000..
But all depends if all goes well.... Ill be driving outta here awith a GTR.... :P
Thumbs crossed!
V33: Were did you get this clutcn done????
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116622
Hmmm - building that stinks?
yeah it smells REALLY bad, dunno what they do there, but it is down the road from the "mouse house" (where they do testing on rats). sometimes whent the wind goes the right way,the smell covers the whole site (across the road)
yesterday near the golf course on H'marsh Dr, black 32 GTSt heading towards F'wick. sorry was too busy gawking in the mirror because I thought there was a 'line behind me. saw 4 of the best tailights in the business disappearing and thought bugger, missed one.
Coulda been me, what time was it?
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116745
had it done with Joe at skyline performance, couldnt have asked for a better job really, only cost me $310(cash) which was around $150 cheaper than anywhere else i got a quote from, i had to wait a few minutes longer than he said it would be so when it came to pay time instead of 350 he said 310, he's really quiet but he does good work and im always happy to take my car there, but if ed will fit it for the same price then i'd ask you to go there, purely cause he's done so much for alot of us.
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116758
spotted sinista on the way home gave him a wave. funny how i have never seen the car before then all of a sudden bam twice in 2 days :( car looks even better moving too :) ps your far left break light is not working :P
Thanks - a bit of weekend maintenance, I'll add that to the list. Spotted you up ahead and just needed a closer look ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116995
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
