Spotted! me driving like a grandma because my cluctch slipped to the point where it revs whenever you put your foot down! hooray! booked it in with Ed, looking at $1000 for a new Exedy clutch installed, apparently slightly better than stock. I'm not a lead foot so it should do, but ouch! $1000 so close to christmas! i could cry!
Sounds like me!!!
My clutch is ***ced.... Does the exact same thing... Im after the Exedy Ceramic clutch, got prices for just the clutch.. comes to around $1000..
But all depends if all goes well.... Ill be driving outta here awith a GTR.... :P
Thumbs crossed!
V33: Were did you get this clutcn done????
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116622
Hmmm - building that stinks?
yeah it smells REALLY bad, dunno what they do there, but it is down the road from the "mouse house" (where they do testing on rats). sometimes whent the wind goes the right way,the smell covers the whole site (across the road)
yesterday near the golf course on H'marsh Dr, black 32 GTSt heading towards F'wick. sorry was too busy gawking in the mirror because I thought there was a 'line behind me. saw 4 of the best tailights in the business disappearing and thought bugger, missed one.
Coulda been me, what time was it?
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116745
had it done with Joe at skyline performance, couldnt have asked for a better job really, only cost me $310(cash) which was around $150 cheaper than anywhere else i got a quote from, i had to wait a few minutes longer than he said it would be so when it came to pay time instead of 350 he said 310, he's really quiet but he does good work and im always happy to take my car there, but if ed will fit it for the same price then i'd ask you to go there, purely cause he's done so much for alot of us.
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116758
spotted sinista on the way home gave him a wave. funny how i have never seen the car before then all of a sudden bam twice in 2 days :( car looks even better moving too :) ps your far left break light is not working :P
Thanks - a bit of weekend maintenance, I'll add that to the list. Spotted you up ahead and just needed a closer look ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/96/#findComment-1116995
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
