spotted a few today
Blue (R33/32) Didnt get a good look as it came flying up behind me near wanniassa in the dark, pulled a Uturn on the roundabout and went back onto athlon. Anyone from here? Thought it was some guy in a commodore or something wanting to race
Black S1 33 in tuggeranong at 8:30, think i got a wave, didnt see properly :X
Maroon 33 on athlon heading into tuggers about an hour ago
https://www.sau.com.au/forums/topic/30059-spotted/page/357/#findComment-2712349
spotted quite a few skylines yesterday.
red r32 4 door gts-t with a r32 gtr style wing
a maroon r33 gts-t driven by a blonde chick driving behind me in woden (didn't wave since she was pretty hot and didn't want to look like I was a sleeze haha)
https://www.sau.com.au/forums/topic/30059-spotted/page/357/#findComment-2713800
Spotto'd a blue R33 parked in Civic, looked like a resprayed GT-R. Had the full kit, fat rear end etc
saw that yesterday too, quite nice,
today i saw Terminal driving down the ramp at work, 2 questions, who do you work for and how do i get to park on site?
https://www.sau.com.au/forums/topic/30059-spotted/page/357/#findComment-2714716
Ahhh, yes the age old secret carpark trick.
I work for Bovis Lend Lease, and we all get free parking in the city, well until 14 december when the 2nd stage of the canberra centre opens. only BLL employees are currently allowed to park under there, but there's no security gaurd stopping people going down anymore like there was a few weeks ago.
https://www.sau.com.au/forums/topic/30059-spotted/page/357/#findComment-2715289
ahh yep gotcha. i noticed that quite a few of our blokes (odg) park down there too, theyre working at the cinema, not sure if thats bogus or cc's job. not to worry, think youll see my car there on fri, sick of paying for parking
https://www.sau.com.au/forums/topic/30059-spotted/page/357/#findComment-2715870
nah it wasnt theo, not sure if it was his GTR, was gonna take a pic of it when it was parked but cass said not to. was a tubby guy with a mullet not that it explains much... but yeah absoloute tosser, thought hed slow down when he saw me and cass so close to the car, but he didnt, almost flattened us, what a knob.
https://www.sau.com.au/forums/topic/30059-spotted/page/357/#findComment-2716433
Saw 2 black 33s today
very shiny (blinding in the right sunlight) driven by a blonde girl in woden at the lights near skyplaza at around 5pm
Series 1 with large dent on rear quarter on the parkway in the morning
https://www.sau.com.au/forums/topic/30059-spotted/page/357/#findComment-2720926
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
