i looked all over the place for widebody32 but couldnt find him yesterday ;)
The only line i spotted at summernats was that gunmetal grey r32 gtr with white p1's and it was just parked off to the side eg not competing.
what about me?! you saw me!!! dammit i shouldve just charged you the $8 for water :D
also saw nik today, but today at nats sucked, shit weather, not as many cars etc... burnouts were ok
Edited by SKYLVIA
https://www.sau.com.au/forums/topic/30059-spotted/page/368/#findComment-2800543
what about me?! you saw me!!! dammit i shouldve just charged you the $8 for water :)
I said the only "Line's" i spotted last time i checked you were not a car :)
but yes i did spot Beau being very generous with the water appreciate it bud :huh:
https://www.sau.com.au/forums/topic/30059-spotted/page/368/#findComment-2800710
Late Spots.
Spotted TeeJay1600 on thursday night at braddon servo. great combo, black car with black rims. that's my next favourite after white car with white rims.
also spotted XAA-108 on northbourne on thursday night aswell. got a wave. damn those rims have huge dish. what rims are they?
also got defected while leaving canberra on friday. heaps of police on the road facing traffic towards canberra for summernats. But one of the Golbourn police decided to be pick on me. Pasted him doing 110, he was facing the other way in an unmarked xr8. he did a u-turn, went after me and pulled me over and said it was a random car inspection.
anyway, need some parts now. I'll post in the parts needed section. Hope no one else got defeted over the weekend.
https://www.sau.com.au/forums/topic/30059-spotted/page/368/#findComment-2802626
ahh man! That sux! Hope it all doesn't set you back too much.. at any other time of the year it wouldnt have happened!
Keep us up to date!
Saw white GTR turning into O'Halloran Cct, Kambah.
https://www.sau.com.au/forums/topic/30059-spotted/page/368/#findComment-2803580
yeah i was in the coupe. im only running a 3inch exhaust and a FMIC. stock boost as well! our mate in the 4 door has 'upgraded' to an RB26! its running close to stock as well, so it doen't go as good as what it could... yet!
https://www.sau.com.au/forums/topic/30059-spotted/page/368/#findComment-2803781
Your kidding...? I wondered why we only beat it by a little amount... went very well though! Cant wait to see how well it will go with more boost. Your cars all looked great together! Was good to see SAU out there representing!
Dayne
Edited by LO_R33
https://www.sau.com.au/forums/topic/30059-spotted/page/368/#findComment-2803882
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
