spotted a white R33 with blue tribal decals running down the side, heading southbound along northbourne ave around 3.15pm. looked nice... then spotted a silver R34 4 door with buddy club wheels stopped on the barton hwy around 4.30ish, swapping drivers...
https://www.sau.com.au/forums/topic/30059-spotted/page/429/#findComment-3287540
Hey,
Do you guys go to the Southern Cross gym in Woden?
I go there sometimes (when Im not working) and I see a few Skylines every now and then... Mine is the silver R32 Gtst with GTR body kit, you should come and introduce yourselves, stop being so rude! :) :)
Sure man, if I see you about near your car, ill hollah out :rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/429/#findComment-3288240
Un(spotted): My silver R33 S2 (YDT...) being at Trojan just short of 2 months now (!!!) :) I know I asked for some parts to be ordered which added another 7-10 days, but far out - two months. :\ Never been this long without the car. I'm wondering if something untoward has happened and they are looking for something similar-looking in Japan to import to give back to me instead :rolleyes:
Anyone been out that way getting serviced and noticed it hanging around?
</RANT> Anyway, I think the guys are doing their best... must just be (VERY) busy, I'm just missing it... :)
https://www.sau.com.au/forums/topic/30059-spotted/page/429/#findComment-3296144
Finally got to spot a lot of skylines
Silver 33 exiting multi-story carpark in Civic around 1:30pm (only saw the front, dam traffic lights)
Dark Grey and Dark Red 32 GTRs in Fyshwick around 2:30pm
Silver 33 Turning off northbourne towards Dickson RTA around 3pm
White 33 heading down Antil street through lights at 3pm aswell
aswell as the white 33 and gold 33 in Fyshwick
https://www.sau.com.au/forums/topic/30059-spotted/page/429/#findComment-3298721
Spotted me drivin around your town at about 1am this morning Alex (baconer)
there is some MANY animals out there.
haha what the hell were you doing out here 1am on a sunday? Hunting?
Yea if it isnt rabbits, turbo bunnies (first time i saw a hare i couldnt stop laughing, they run along normal but as soon as a dog gets close they hit boost and go from 30km to about 100km in half a second - hence turbo bunnies :thumbsup:) or kangaroos then its peoples stray dogs, shits me off people dont keep their dogs locked up at night, one night im going to hit one and probably get shot :angry:
https://www.sau.com.au/forums/topic/30059-spotted/page/429/#findComment-3299404
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
