That is exactly what i saw...
Just checking; did it have dealer plates on it? And black in colour? There are a few in Australia, but as personal imports, so they can't/haven't been complied to be legally driven on our roads... BUT there is one in Canberra that has been driven about with said dealer plates...So, not that I really doubted you; it may've come across that way, but the thing shouldn't have been driven about...just yet....
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3607943
I didn't see a plate on the front, and didn't notice if there was a plate on the back. So dealer plates are quite possible.
If you check the R35 section of the forum there is someone else who claims there is one in Canberra.
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3608242
Looks like the GTR in Canberra was driven down from Sydney (lucky bastard) fairly recently. Someone else spotted it while driving from Syd to Canberra:
If anyone knows Jerry or the guys at J-Racing well, try and get them to bring the car to Shannons Wheels this March :banana: We will pretty much win that entire event if the R35 makes an appearance.
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3613256
yes it is. my suspension is the same as his 33. when i asked Chris at Inline what should i do suspension wise, he said to go and look under Bob's 33, so i did. "nice.." i said. "thats what i'll do to your car.." said chris. "awesome.." said me... :worship:
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3613770
Yep; the grey 35R is definately Bob's. And Jerry tells me he doesn't have one, which is good enough for me. Whilst the car isn't complianced, it seems a mere matter of time, tests and red tape before Bob gets to drive it on the roads. The question I need to ask him is what he's done with his daily driver 34. Would be a nice garage: 33,34 & 35 model GT-R's!
Spotted today: a black 32 GTS-T, nice wheels, well fitted FMIC, driving into Fyshwick as I was passing through. Saw the driver looking, so I waved, but it mighta looked a bit weird...getting a wave from a gold Forester! I long to be more recognisable behind the wheel of a certain white 32.
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3615174
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
