Spotted Trozzle's car parked on the road out the front of Gentech in mitchell yesterday arvo
Yerp, was getting engineer's certificate at Canberra Motor Works. Unfortunately didn't get it due to a few things (one of which is worrying lol), however shouldn't be hard to fix up. Unfortunately I foresee having to cancel the rego on my car before the lack of defect clearance does it.
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250315
Something to do with the diff/cradle mounts is allowing the whole diff to move up/down around 10mm
Yeah you're right.. just a little worrying :/
Spotted Troy and Richard hugging each other as the sun went down over the lake. They looked to be eating takeaway.
Hope you boys had fun
Sin and his troy boy
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250393
Batted Savs with Mayo & Choc tipped Bannanas, your Favourites. You should've come............
Gags :sick:
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250489
Cheers Josh!
Yours had a nice tune when it took off as well
I spotted a r31 parked outside of Pedders in Phillip as I dropped my car off for an inspection
Spoke to the guy who owns it about his Rims dont know if his online here
Also spotted a Silver 33 cruising around Phillip.
Then Josh rocked up for a surprise visit just after I talked to Natrad about my constant coolant problems
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253128
Pedders bad :down:
Rear calipers installed on wrong side and upside down. Pads on wrong way in calipers.
All new suspension installed but not adjusted. Camber out, toe out, F/R balance alignement out.
Bled in wrong order, air in brake system. Did not and would not blead ABS - WTF.
3 x returned for fixing - no luck and they had no idea.
Sir your brand new Rotors/Calipers/Pads/braided brake lines/BMC have no problems. Your car just does not stop very well and its got very spongey brakes. You should look on the internet and see what you can do to fix that !!!!!
Yes I went back and told them what was wrong and that I had paid again to have it done.
1 minute at ACT brakes - your calipers are on upside down and wrong side sir. Fixed. Felt alot better.
But these guys didnt notice pads installed correctly. Went back twice more. Sir there is nothing more we can do !!
Both of the above shops have "Brake Specialists" in their business name.
ESP identified and resolved all brake issues :thumbsup: and bled the ABS as per what you are supposed to do !
Capital steering and suspension for dialing in suspension :thumbsup: . Booked in Wednesday.
I should go get the spare key to my car and go steal it back haha?
Okay well there goes $14 for the inspection lets see what they come up with that's wrong with my car
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253190
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
