spotted myself booking the GT-R in to ultimate tunes to get it running.....=(
Also spotted a black rsfour stagea in conder this morning.
Spotted a black R32 GTR on betty maloney cr near the park... on friday.
anddddddd spotted that bloody R34 v-spec 2 in tuggers kmart carpark.its there to tease me!
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6383315
You cant really called that a spot when you have 2 skylines in the drive way.
"Oh i spotted my stagea sitting in my drive way again and again" lol
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6383828
Spotted a purple 33 at the units then came around the corner and saw a Bayside blue R34 GTR,
I got out to open the garage and spotted an R32 GTR.
As I closed the roller door I saw a Silver 34 GTT parked in my driveway
Just taking the piss :D
Oh and that Bayside Blue 34GTR you spot at tuggers lives in this complex too.
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6384075
spotted myself limping home in the Stagea.. I think I may need new coilpacks.
You guys are hillarious!!!!
Whens the next chance for us all to catch up?
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6384831
Spotted Azathoth going past EPIC today 1:50pm ish.
(I was in the work truck.)
Spotted the RS4-S Black Stag with Green Wheels on Thursday on William Hovell at 8:50 ish.
Shortly after that, saw a nice R34 GTR Champagne ish colour in traffic near Glenlock Interchange.
(I was in the work truck.) --->>> MINT KITCHENS. ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6385703
Woulda been the missus driving. Still need to get that actuator off ya. Backed up my phone and lost numbers. SMS me when ya get a chance. Cheers
https://www.sau.com.au/forums/topic/30059-spotted/page/743/#findComment-6387098
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
