White R34 4door with Black rims and Black Bonnet at Repco in Mitchell parked next to a Black Corvette, yesterday and today.
Alway a nice Black R33 parked out the front of Love Tyres and Mechanical in Mitchell also.
https://www.sau.com.au/forums/topic/30059-spotted/page/753/#findComment-6490311
