Lol thanks dude, what do you guys do around here? meaning the car scene! i only know a few people here and when I mention "psi" its hopeless lol
We procrastinate alot and pike out on organised events, but occasionally stuff up and actually attend. :laugh:
Welcome to the ACT SAU ! (good bunch of peeples around these parts) :yes:
Ladies with Skylines always raises an eyebrow or two. :woot:
Post pics please?
and maybe some of your car too? :D
https://www.sau.com.au/forums/topic/30059-spotted/page/814/#findComment-6792171
The rear-view-mirror took a long time and dedication to do. I just wanted to let you all know how impotent this project of mine was. I had to know the answer.
It's Swirl in my world Rob :D!
LOL ! Hopefully being impotent isn't part of your world.
https://www.sau.com.au/forums/topic/30059-spotted/page/814/#findComment-6792180
Post pics please?
lol havent had the Camera out in a while so dont really have any updated photos of the car. u'll no its her when you see it cause she has ST34LF as its number plates. p.s good to see guys here are just as smooth with there lines lol
Edited by EllzR34
https://www.sau.com.au/forums/topic/30059-spotted/page/814/#findComment-6792243
Are you Northside or South?
https://www.sau.com.au/forums/topic/30059-spotted/page/814/#findComment-6792263
I feel lied to !
WTF? lol Dude what are you on today? (can I have some pleeez?)
Oh you mean gods country with all the valley views. ;-)
Valley views = Plumbers Crack? :(
I like this side o town. Easy to get anywhere including outta here.
https://www.sau.com.au/forums/topic/30059-spotted/page/814/#findComment-6792320
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
