Spotted a silver 33 series 2 with a Trojan sticker this arvo leaving Mitchell on the GDE. Big rich stain on rear bumper and ding on passenger side.
Lol Not a Pulsar. Not sure what that link was too but I managed to find this spotted! of yours. This is the car I recently purchased and will be requiring wheels for to pass rego!
Small world! :)
...Well, maybe just small Canberra :P
Edited by dontyellpl0x
https://www.sau.com.au/forums/topic/30059-spotted/page/818/#findComment-6797765
Small world! :)
No way! Big Country Town we live in. :D
https://www.sau.com.au/forums/topic/30059-spotted/page/818/#findComment-6797771
11:05 spotted a S2 R33 4door, Silver with Black bonnet near Kippax Caltex.
prior to this, I spotted a HOT young chick in a Black Holden Cruise with P plates, hit the brakes at an amber light on Coulter Drive, right in front of me and I ended up actually rear ending her !!! (car) lol
Slowed down enough to cause NO DAMAGE to either car. None. :blink:
Scared the Crap outta me. :D Sooooo Lucky !
https://www.sau.com.au/forums/topic/30059-spotted/page/818/#findComment-6798994
