i was on my way to tuggeranong and i could smell something burning like oil. quickly pulled aside and there was smoke coming out from the engine where the air con compressor is and also it was making noise. as i had the air con running on max, when i turn it off the noise was gone but it was still smoking.
Got it towed home just to be safe but was not fun waiting for like 2 hours on the side of the road
Dont know what the problem is but i will find out tomorrow
https://www.sau.com.au/forums/topic/30059-spotted/page/919/#findComment-7169680
Sounds like the Radiator couldn't handle the really hot weather and it cooked. Hopefully no major damage was done....
https://www.sau.com.au/forums/topic/30059-spotted/page/919/#findComment-7170056
Spotted Tom in his Blue 300z in Fyshwick around 2pm.
Silver, Wingless 4door R34 with NSW plates near Grevillea just before 2:20pm.
Dark R33 GTR? coming out of the Orange tunnel as I was heading in, just after 2:20pm.
https://www.sau.com.au/forums/topic/30059-spotted/page/919/#findComment-7173269
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
