Saw a silver R33 GTR with chrome AMEs in Dickson this morning just before midday. Then a wine red R33 GTSt with dark coloured wheels driving through Dickson, as well as a black R33 GTSt parked in the carpark here at work. All up, a very Skyzer morning.
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908533
maroon 32 GTS-T civic carpark, not sure if it was a GTR or not, the "DRIFTO" plates was what caught my eye
Yeah Andrew that's me.
It is a GTS-T
G'Day Mark, yeah I probulary gave it a hit! Can't resist that surge when she comes on boost. Although I was suppossed to be taking it easy with the new diff for 500km. So next time I may give it some more.
Yee - Haaa!
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908606
Just wandered over to Dickson shops for lunch and spotted another R33. Looked like Ford's Blueprint Blue with Signal stickers, a nice front mount, three spoke Trial wheels. Sounded real nice when he took off.
All this Skyline action really makes the whole 'being at work' thing easier to swallow :D
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908633
Black 33 series 2 turning into Tennant St Fyshwick this morning.
(Not Ewen I don't think)
Nah, it wasn't me, i don't drive my car during the week, or into Fyshwick.
Might of been dukie? or perhaps another Black Series II we've not yet encountered.
Once you two (leech and p1r4t8r) have yours, i make it my mission to get every black Series II we can find together for a mad photo :D
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908639
was that kirt's 33? he went to work just before three, and lives near dickson
nice to see you ont he forums drifto
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908682
Hey Guys,
That was me. Just goin to work. The colour is actually R34 - GTR - Bayside Blue. The car with the Advan Split Tri Spokes??? You work in the TransACT Building as well Aurora??
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908700
Hey Andy,
That was me in Dickson givin it a bit of a hit. He He He.
Does not take you long to post after work. So really when are you going to join the realms of the Skyline Owners???
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908709
Hey Guys,
Yeah i do. Oh, your car doesn't have Advan Tri-spokes?
Yeah, the car was gone pretty quick, only got a quick look.
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908791
Yeah they are Super Advan Tri Spokes. 18 x 10. They are sweet wheels just rubber is the only killer - $250.00 a tyre. Next time you guys get together. Give us a Holla
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908902
$250? Get over it :D
I payed $490 a corner for 18 x 9.5"s (265/35/18).
What tyres are you using? I want some of THAT action :)
Damn $450.00 are they gold plated??? Go and see the Tyre Factory in Queanbeyan. They know there stuff. I have not put them on yet - I need to - Canvas is no good. But when I got a quote they quoted me $250.00 and said they were a good tyre. Check em out - Yass Road Queanbeyan
https://www.sau.com.au/forums/topic/30059-spotted/page/35/#findComment-908966
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
