Spotted red R31 sedan down in Gordon, R31club stickers on the 1/4 windows, looked real clean. Nice.
Also...SPOTTED LEIGHS CAR! YAAAAAAAAAY! COngrats buddy! Great to see you finally got it. Like the GTSV-i sticker...looks neat :) Man it's a clean looking car.
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-944112
Also...SPOTTED LEIGHS CAR! YAAAAAAAAAY! COngrats buddy! Great to see you finally got it. Like the GTSV-i sticker...looks neat  Man it's a clean looking car.
woot yea i i was trying to work out what the hell it meant then i put it together
GTS (makes sence)
then take the S and you have SVI (the place i imported it from) thats my assumption of it anyways but i think i will be removing it as well as the gts25t sticker in a while. i am contemplating actually getting some proper letters that just say GTS-T or GTS25T like what you see on most of the other cars around it just looks so average the GTS25T sticker thats on their. but thanks for the comments :D now i just need to put the bigger exhaust on and get rid of the pea shooter :mad:
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945471
Man, it's so stock!
Not a bad thing by no means, it's a great base. And i think it's better than getting some Japanese guys half finished mods.
Looks real good man, as soon as i can drive my car again, i'll snag a park next to you :D
08Elf-> Yeah there is :mad: Are you in the Transact building as well?
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945550
08Elf-> Yeah there is :D Are you in the Transact building as well?
Yep i work there.
I got the Black R32 GTS-T, stocker.............except the pod filter and exhaust it came with when I imported it from japan oh and the GTR rear strut bar.
What sort of R34 is it? i know it turbo, cos I hear it ppppppssssshin!! down the street at lunch.
Anyone know somewhere there are plans or diagrams for a cold air box, for an R32??
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945727
It's an R34 GTT, has an exhaust, Frount Mount, Powder coated white standard wheels lowered and a cold ait feed by the looks of things.
Welcome to the Forums by the way.
Where in the building do you work? ACTEW? TransACT, Teletech? ACCC?
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945749
Yeah i reckon. I've been here 3 months now, and i like it, everyone is friendly, etc. But yeah, you're right about not knowing some people.
Either that or some people just don't want to be known. SIt in the back corner alone and don't say a word.
https://www.sau.com.au/forums/topic/30059-spotted/page/41/#findComment-945832
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
