Spotted Richard (I think!) on Drakeford at about 1pm.
White R33 with black rims near Chisholm shops about 1pm and then saw him again I'm pretty sure, same area, about 6.30pm.
yep would have been me after dropping the GF off.
Got a toot from some one in Queanboganville yesterday. Didn't really see who but it looked to be a dark grey ford ??
Stuck my arm out the window for a backward wave.
https://www.sau.com.au/forums/topic/30059-spotted/page/917/#findComment-7166937
^^^^^ ... yep, agreed. I do the same and sometimes while I'm waiting I take pics .
that is by far the best looking 34 I have seen, its perfection !
tho is it just me or does the numberplate look a little wonky :P
https://www.sau.com.au/forums/topic/30059-spotted/page/917/#findComment-7167095
yep, I got a toot last time I was there.. and im going back to pick up the sister in about 20mins....
saw a grey 32 young guy driving, heading to tuggers from Calwell way yesterday
and what seemed to be a s13 siliva with a skyline bar... had a p plate zip tied on the back, then it went and was fluttering like to tomorrow in tuggers last night at about 7pm?
https://www.sau.com.au/forums/topic/30059-spotted/page/917/#findComment-7167101
7pm...Silver S2 R33 with R34 GT rims, P plate, young dude driving and 3 young passengers in the back. (none up front) WHY??? :wacko:
I saw that in an s15... makes no sense! all I could come up with is that he was picking up his gf or something
https://www.sau.com.au/forums/topic/30059-spotted/page/917/#findComment-7167411
Thanks for the compliment Andrew, very much appreciate it, and I do love my 34 ... but have you seen Richards 34, I've only seen it in pics but it is a lot closer to perfection than mine.
Oh and the number plate is straight but yes I agree it does look a little wonky in that pic .. sh*t .. might go check it just in case!! :wacko:
https://www.sau.com.au/forums/topic/30059-spotted/page/917/#findComment-7167414
My guess ...... 'no Maccas in the front dude, get in the fnckin' back with that sh!t where I cant see it' .... :P
Oh well .. just adding to the conversation .. :glare:
https://www.sau.com.au/forums/topic/30059-spotted/page/917/#findComment-7167418
if Richards AKA: Rosie, I have seen it once , it does look really nice :)_
https://www.sau.com.au/forums/topic/30059-spotted/page/917/#findComment-7167424
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
