TAKE OFF OIL FILTER HOUSING AND CHECK FOR BLOCKAGES
DOES THE OIL PREASURE RISE UNDER ACCELERATION?
no it doesnt really, just seemed to rise alit bit as the engine got hotter (prob as the oil got thinner and could bypass the blockage into the oil pressure gauge)
And to answer all the other question, yes i do understand the importance of oil pressure, but before u just blindly flame me, maybe have a closer read of wat ive asked. To clarify, i am wondering whether a blockage in the oil fliter housing/ damaged orings would be bad in the short term in terms of damage to the engine. The way i understand it (i could be wrong), if either these 2 are the problem there is still oil pressure in the engine, but the oil is just not getting to the pressure sender and hence not displaying on the gauge. I realise if its blocked, the oil is not getting filtered properly and over the long run this is bad.
I also did abit of research and apparently some ppl have had the same symptoms and found out it was a faulty oil filter. I didnt buy a ryco this time as i normally do, but i dont really see how a faulty oil filter could cause this problem.
Thanks for the help guys so far, good to be able to discuss this on a public forum... Ill keep this updated as i go just in case any1 else stumbles onto a similar situation.
ok, to save everyone your headache. take to mechanic or do it youself. borrow or buy a aftermarket oil pressure gauge.(not autometer or any one that uses olives on nylon tubing)
the thread on the block/engine is 1/8 npt.
install it, and check. ps..every car really needs one. factory is shit.
my car didnt have a factory gauge yet the factory light saved my engine from grenading really big time.
my oil pump cracked (33gtr pump with a crank collar on a 30det) and the oil light picked up the pressure drop before the tuner noticed any noise through his knock headphones. we got it shut off etc before there are even any marks on the bearings.
will be installing one now however. what brands are best?
Edited by SirRacer
my drag car uses a fuel and ignition cut out system should oil pressure fall below 30psi with an override switch for start-up. Its already saved 1 engine due to an oil pump failure on launch (N1 oil pumps don't like banging off the limiter with ignition cut at 9500rpm)
did you renew the oring on the housing shaft?
my guess is its either faulty or missing.
Is this the housing shaft you are referring too???
Pic is my old motor which as far as I can tell never had an o ring on there?
there is a ring on the end which could seat an o-ring an one almost flush with the block which could maybe as well
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
