  • Replies 230
sofly - second batch of pics perfect just the 20mm spacer in first pic made it stick out to far but you didnt explain that hence calling it mexican..
aside from that this thread fails.. thread is "wheel fitment, post YOUR wheels" for the most part its random internet pics and cars that are wheels slapped on and need more this, less this to achieve "fitment" maybe should have just made it post your wheels thread..
heres some pics of mine... i consider this conservative as i have only lipped the guards. wheels are 17x8.5 and 17x9.5 panasport g7's and were used a test fit... be prepared for what i have planned when my rig is back on the road in 2011.
and for the haters... this was my daily.. and i never got pulled over.. aslong as the top of the tyre is inside guard its not really a problem. also the rears were almost flat... i can show you pics of my skid tyres and you'll see that just about the entire tyre is worn.
i dont see the point in having a lame (safe) offset... it looks like a commonwhore and is crap. and soo many cars are running around with these kind of offsets and stretched tyres, so i think the unsafe claims of stretched tyres can be put to bed... they just dont hold up anymore.
cheers
Linton
whats the difference in sizes? did you sacrifice some dish for width?
recieved my 17x9.5J +26 / 17x10.5J +/-0 VS-KF's the other day too bad im heading to thailand on sunday got no time to organise tyres and get em on :rofl: im itching to get back already haha, going on an R32, will post pics when on.
recieved my 17x9.5J +26 / 17x10.5J +/-0 VS-KF's the other day too bad im heading to thailand on sunday got no time to organise tyres and get em on :P im itching to get back already haha, going on an R32, will post pics when on.
my last rears were low brake clearance , the new ones are hi :D
fronts are 16mm more rears are 5mm more (and by more i mean less;) )
R34 sedan, 18x9.5 +15 JIC wheels, 235/40's all round, fronts really need a 225, front guards lipped and slight pull, rear's i still need to lip the guards then i can give it more low, just havnt had the time. Work in progress.
if anyone wants them
$8 and there yours :rant:
what? don't sell em to anyone. you'll get tards with sunken battleship fitment sporting them.
i say you only get to have those if a panel of experts deem your wheels to be truly hellaflush.
amen
are you thinking of the same car im thinking of shan? :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
