I have a problem with my rear brakes which is baffling me. Brand new discs and pads, brake pistons go back easily by hand ( just), caliper pins all greased and slide easily, brakes bled. I came home from work today, 5 miles, braked maybe half a dozen times, when I got out I could smell the heat and the discs were literally glowing red!!!! I must be driving with the rear brakes on all the time, they are not letting off. It is definately not the handbrake cos I haven't used it since putting on the discs and it is adjusted to not rub. Heat was also the reason the last discs cracked so it is not new but I want to sort it before I f**k these discs. I am tempted to buy replacement ( the same ) calipers but I am not convinced it is them cos it is on both sides.
There is one brake line which runs to the rear and then it splits to each wheel, not sure how the ABS works out which wheel is which, but I am thinking could it be this splitter unit or maybe the one in the bonnet, ( think the ABS unit) that seperates the fluid to the front and rear and has electrical doobries on it.
The front brakes are fine.
Any help anyone please!!
https://www.sau.com.au/forums/topic/301629-very-hot-rear-brakes/
No idea what's causing it but doing the easy things first I would
1. (if you haven't already) replace all the fluid with something like Motul RBF600 - worth doing anyway and it may push out some foreign material in the system.
2. Go talk to a brake specialist and see if they come up with a likely cause.
3. Swap out the mastercylinder
4. Swap out the abs unit ( I have a spare unit but maybe someone closer has one).
Good luck!
first thing i'd be checking is the handbrake shoe adjustment, i'd say they are up a little too tight and are rubbing on the rotor as you drive causing the heat buildup on the rear rotors only. it could be either the shoe adjustment behind the rotor or it could be the handbrake lever itself. i've seen it before on one of my old cars, never got hot enough that the rotors were glowing, just changed them to a nice blue colour. you said you've checked it but maybe remove the shoes from the handbrake assembly just to eliminate them as the problem.
Edited by QWK32
no it is definately not the handbrake. As I said I have adjusted the handbrake so that the shoes are not making contact with the drum at all and I haven't touched the handbrake since I put the new discs on. i just feel it isn't the calipers as they are both hot.
Probably still a good idea to remove the brake shoes or at least back them right off. At least it is a simple task and the park brake is the most logical suspect. Also I noticed when I used to have that kind of brake that it was possible if your left foot was in the wrong place for the parking brake to fail to release completely when you pull the lever.
as Bob has said, still a good idea to remove them just to help rule it out as a problem. i remember stuffing around a few times trying to set up the shoes so they didn't bind on, even though they felt good with plenty of clearance when sliding the rotor on, they still locked up once i started driving.
you said you changed the rotors for new ones, are you sure the rotor offset was exactly the same as the original nissan ones, if its out it could cause the rotor to rub heavily on one side of the callipers brake pads. i haven't had to go through changing the rear rotors yet but from what i've read its hard trying to find a perfect matching rotor???
As I said before, that is exactly what I have done with the handbrake. It is backed right off and the shoes are clear of the drum and I haven't used it since. It is NOT the handbrake, the calipers are binding on. I'll give it another free-up this morning but I know that the calipers slide ok and the pistons go back fairly easily. It is happening on both sides which is the odd bit, it's almost like the pressure to the rear brakes is not being relieved when I take my foot off the brakes but the front brakes are fine. that is why I was thinking of maybe the ABS unit being duff or something. I suppose I'll have to try replacement calipers first just to make sure it isn't them. It's a pain in the arse cos it's my only transport.
rotors wre the same and the caliper carrier is clear and the caliper itself slides so I can't see that as the problem. It may just be the pistons are too stiff, I'll try recleaning and greasing them today but it seems odd that they are both doing it.
How are the brakes if you need to pull up quick ? Are the fronts working fine?.....Odd problem that could be very dangerous.....I wonder if its worth cleaning out the whole system and having master cylinder checked
had another look today, passenger side rear wheel turned easily with only slight scraping of the pads. driver's side ( the red hot one last night ) I could just about turn it. I regreased the pins and around the contact points etc and pumped the piston out and it pushed back in nice and easy, not quite by hand but nearly on the passenger side. On the driver's side I did the same but pumped the piston out, took the rubber boot off. the piston was very dry and had rusty score marks on it. I wet and dried what I could, using brake fluid as a lubricant, then cleaned it off, put brake fluid on the piston and pushed it back in ( not by hand ). I then pumed it back out and repeated the process. Now I could push the piston all the way back in by hand, pumped it out and pushed it back in again by hand. I then kept the piston in and bled that caliper. Then pumped it back out and pushed it back in again by hand. Put the boot back on, clip is fiddly, then reassembled everything. Put the wheels back on and pumped the brakes a few times. Both wheels now turn with minimal scraping of the pads. Hopefully that is it sorted for now.
I think I should really replace the calipers with some newer better condition ones before it happens again!!!
Hopefully you have solved it. I had a similar problem with the fronts on a Toyota Corona and after cleaning them up with sandpaper to get rid of all the score marks but without success i figured that there was so much clearance that the pistons were able to tilt and jam. Another set of calipers from the wreckers fixed it.
You should be able to test the brakes by seeing if the car will roll away on a very slight incline or be held by sticking brakes.
yes that is what was happening, even on steepish ( sort of ) inclines and the wheels were hot. I will keep checking it after every drive cos I am paranoid about it now!!!! I'll look out for a replacement set of calipers. I would like to upgrade but money says I'll have to stick with stock items, just hope the ones I buy are better than mine, always a risk.
I have managed to get a pair of ecr33 r33gtst rear calipers at a good price off ebay. They haven't turned up yet but I have a few questions.
They are the 2 pot ones.
Are these calipers made from aluminium?
To do a seal change on them, do you need to split the calipers?
I understand ( correct me if this is wrong please) that stagea rear discs are 280mm and the r33gtst ones are 296mm?
The stagea rear discs are vented, are the gtst ones or are they just one solid disc?
I shall try and keep my standard ones going until I have refurbed and painted the gtst ones and saved up for more discs and pads!!
rear 33 brakes are 297 (1mm bigger than the 33 fronts) they aren't as thick as the fronts but they are vented (99% sure they are, my 32 rears were)
make sure you put 33 rear rotors in there cos the 33 ones are prob different offsets
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
