  • Replies 201
Posted Images
got my entry stuff today,and invite for Kadina show ? anyone setting up that one ??
Glad to hear you got your Entry stuff :P. As for the invite to Kadina, is it an entry form, or just an invite? If it is an entry form, could you scan it and upload it for others to use, as I MAY organize it...if no-one else wants to.
Glad to hear you got your Entry stuff :P . As for the invite to Kadina, is it an entry form, or just an invite? If it is an entry form, could you scan it and upload it for others to use, as I MAY organize it...if no-one else wants to.
Yay for the Kadina show. Can't wait for this year's Just need the dat so i can take some day's of off work for a holiday.
you wont need to book off days for the kadina weekend tim.....its on a long weekend and the show is on the sunday....got monday off as a public holiday....
btw i got my entrant pack for the old skool new age show.....:D
btw i got my entrant pack for the old skool new age show..... :P
AWSOME. I take it, it's leave Sat morning come back monday arvo.
You can both come along in my car if ya want
i got a spare seat in my car....:P
Oh yes Kadina...lol I have photos to prove it...lol
another weekend of two fisted drinking and deer hunter...lol ????
and Krishy trying to score with the bar maid..lol
If there is a will there is a way........hence chance to score....i say why not
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
