  • Replies 57
Thats awsome, why you ask, why bloody not, the thing would scream, I went in one years ago with a pos 4 cyl na which was pretty fast, would sound sweet to opened up.
if that thing sinks i think i'd cry....
well der car boats have been done before... half of the asian boats are made like this....
But has anyone seen a 2jz with a big single top mount on it before on a dodgey boat like this? I think not
Is it just me or does that boat look like a prime candidate for filling with water the first time he nails the throttle?
I've run up and down many rivers in Asia (especially Thailand) (and in the ocean occasionally) on boats like this... they go like stink in a straight line, expescially the big ones on Mae Naam Chao Phraya that can seat about 20 people... but because the direction of push from the propeller is centered in the motor about 1m above the waterline, they have to stop and just edge the boat a little bit at a time to turn it... when they get it pointed where they want it, the drop the prop back into the water, open the taps, and they go like stink...
So any little runabout would eat them, since they can't turn, but they are great fun... kinda reminds me of all of the pussy drag cars, racing means cornering :D ...
BTW, they are generally built like this because of the shallow draft, and because there is usually a lot of floating weeds in the river, so they can easily lift to prop out of the water to clear it...
Cheers
Daewoo
ya but the 2jz is still more reliable than 2 F440 engines lol....
Why the hell would you waste those engines on an ugly red boat?
Because you have that much money you have weird dreams and then go "you know what, im going to get some one to build that". lol.
Also millionairs have Ferrari's, other millionairs have big boats, then there is billionaires that build ferrari boats.
Edited by PM-R33
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
