Have just purchased first skyline and i'm not sure if the boost gauge is reading right, it generally sits in the negative and only goes into positive boost when accelerating hard, is this normal?
That's what its supposed to do?
That is the corect operation of a boost gauge. Under no load the intake pressure sits in a vacuum, demonstrated on the gauge as a negative pressure. Once the engine is under sufficient load and the turbo is "spooling" the pressure will go into a positive "boost" it will continue to climb until the wastegate cracks open and the boost will stabilise at a single value controlled by the wastegate/boost controller.
Have a read of this, good article to explain the basics.
http://www.howstuffworks.com/turbo.htm
Edited by PM-R33
k, cheers for that i also wanted to check just below and to the left of the steering wheel there is a screw with a black cap on it that dosen't seem to do any thing is that just for securing some sort of access panel?
another question, is it common for the exhaust manifold nuts on cylinders 1 and 6 to come loose/ fall off, and is there a special nut/washer type to stop this?
Totally normal.
Just kidding dude. Maybe the studs are broken so they arent staying tight?
Best thing to do would be to find new ones and just put them on tight.... tight tight. Maybe even some threadlocker?
Standard gauge isn't the best. Check the line for it hasn't cracked as they tend to do. It comes off the intanke manifold near the firewall, it's a 4mm black rubber hose
I had this issue. The rubber hose becomes brittle and cracks appear which messes up the factory boost gauge. I had some 4mm rubber vacuum hose lying around which I installed and all is fixed with the gauge. Very easy to fix.
Yep, I had the same trouble. That little hose just gets brittle with age. Also causes a vacuum leak, which harms the boost as well.
A few bucks worth of hose from Autobarn should do it!
  • 4 months later...
hi.. thought i would post here.
this hose for the stock clusters boost gauge, has came off, its still connected to the manifold, but it has came off at the other end, i pulled it and it came from behind the drivers guard.. so while ive had my guard off today, i have been trying to reconnect this, but i cannot find anywere it goes?, can some one lend a hand to were this connects back.. thanx
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
