R32 GTS-T 2 Door Coupe
Hi Guys,
Breaks my heart to sell up, but time to move on, starting my own business and need the cash. I have recently built this up from a clean 2 door shell, and my spares from my previous skyline. Thousands have been spent, this is one of the tuffest 2 doors going around. Its a clean street car with plenty of track/drift focus. Was built to be a street/drift car, but has never seen any track time.
Modifications include:
Engine: Serviced reguarlly, healthy motor, making 210rwk on 16psi
· RB20DET
· Rb25 GCG Highflow turbo
· GCG 16psi actuator
· Sard 650cc Injectors
· Sard Fuel Pressure Regulator
· Z32 AFM
· Custom Intake/cold air AAA Pod filter
· Cusco Catch can
· Adjustable cam gears
· Gates Timing belt
· Gready FMIC
· Splitfire coilpacks
· Turbotech boost controller
· Nistune ECU
· 3” turbo back exausht to twin straight pipe diff back
Gearbox/Driveline:
· Rb25 gearbox less then 100,000K
· Nightworks Urathane Gearbox mount
· Welded Diff
· Exceedy 5 puk button clutch
Suspension/Brakes:
· Coilovers; Buddy Club front, and JIC rear
· Front Nismo strut brace
· CUSCO rear strut brace
· Urathane upper control arm bushes (front)
· DBA 4000 slotted rotors
· QFM A1RM 650 degree hi temp pads
· HICAS completely removed, lock bar and all solenoids and lines removed
· Whiteline Front and rear adjustable sway bars
· R33/s14 Lower control arms
Interior:
· Cusco full cage 6 point with harness bar, (currently just running half cage but rest will be included)
· Rear seats removed with back seat area carpeted
· Sound deadening removed from back seats to the boot
· Drift handbrake button
· Autogauge gauges: Water temp, oil temp, oil pressure, air/fuel and boost.
· Golf Ball shift knob
· Pioneer CD/MP3 headunit
· Kicker 6x9 fited in original parcel shelf with 600w amp
· Momo deep dish steering wheel (same dimensions as nardi deep corn)
· Recaro Recliner bucket seat
Body:
· GTR Bonnet
· Full type m kit
· Gtr front bar (seen beter days, currently cable stiched, very tuff!
· Non turbo headlights (same as n1 without gtr grill tabs)
· Strobe lights in fog lights (very drift/jdm)
· Black bootlid
· 17x9 +30 drift teks all round
This car will not disappoint
Price $14,000 ONO
Will sell for less without wheels, cage, recaro or other bits and pieces, open to offers
Located in South Eastern Suburbs Melbourne.
Call Paul on 0400 200 997
More pics soon.....
https://www.sau.com.au/forums/topic/303214-r32-clean-street-drift-track/
wow, 11k surely this cant last long.
almost thinking about it myself.
good luck with the sale
Cheers budy its soo cheap for what you get, very reluctant to sale, someone should snap it up before i change my mind.
  • 4 weeks later...
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
